IOS for WS-C2950-24
behrooz1361
Hi all
Is there anyone who would be able to help me to download the below IOS version from Cisco? I only need the link as I do have authorization to download IOS s.
Product : WS-C2950-24
Required IOS :   c2950-i6k2l2q4-mz.121-22.EA14.bin
Behrooz
Reza Sharifi
Hi Behrooz,
Unfortunately there is no more IOS available at Cisco's site to download for the 2950 series switches. They are very old, end of life and support.
5 Replies 5
Reza Sharifi
Hi Behrooz,
Hi Reza,
You are right mate, Couldn't find it on Cisco website either. Thanks for your help.
Cheers,
Unfortunately, this link does not work.
Do you happen to have another link? I am having the same issues..
So what is the solution then? Can any other iOS be used? If so which one can work with this switch?
