IOS.sh fetch command. What does it fetch?
stephengun
In the IOS shell, there is a command "fetch" (ie, in the terminal shell). The help says:
NAME
fetch - return data from a path variable.
SYNOPSIS
fetch <var> <path>
DESCRIPTION
Fetch returns a string from an internal path element
Path elements contain internal operational data
 What are these internal path elements? I cannot find any example of this being used.
jsblach
you see the fetchable data with 'show shell data-path'
you can then e.g.:
fetch vendor //oper/platform/vendor
echo $vendor
it will return "Cisco". Who'd have thought that.
