ios upgrade procedure for VSS and stack switches
We have two 6500 configured as VSS, please let me know the best practice to upgrade IOS for VSS switches.
3560 switches are stacked, please let me know the best practice to upgrade for stacked switches.
InayathUlla Sharieff
1.  Copy the IOS from the TFTP to the active blade supervisor card:  copy tftp:///IOS.bin sup-bootflash:
2.  Copy the IOS from the TFTP to the secondary blade supervisor card:  copy tftp:///IOS.bin slavesup-bootflash:
3.  Go to enable mode and change the bootstring/boot variable.
NOTE:  In this step, what we've done is specify that the chassis boot the NEW IOS and also specify that the chassis boot the old or existing IOS in case the first one fails.
conf t
NO boot system flash sup-bootdisk:OLD_IOS.bin
boot system flash sup-bootdisk:NEW_IOS.bin
end
copy run start
reboot
2-
3560
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/64898-upgrade-3750-stack.html
Inayath
refer below docs:
https://supportforums.cisco.com/document/124626/virtual-switching-system-vss-configuration-cisco-4500-series-switches
http://www.thegeekstuff.com/2011/06/upgrade-cisco-ios-image/
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/64898-upgrade-3750-stack.html#mupgrade
http://www.ciscozine.com/how-to-upgrade-a-cisco-stack/
conf t
end
copy run start
reboot
2-
3560
Inayath
Mark Malone
Here is the doc for upgrading a vss through fsu
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vss.html#wp1169328
for IOS-XE just copy image onto USB stick in switch and push it to switche using below , you will need to reload after
software install file flash:cat3k_caa-universalk9.SPA.03.03.01.SE.150-1.EX3.bin switch 1-2
