IOS Versions ADV. IP SERVICES or ADVANCED IP SERVIES
mark.cronin
Level 2
Level 2
I am in the process of selecting an
IOS for our 877 & 1801 routers, I will need features from IP Advanced Services. When I look on the Cisco upgrade planner I get options for feature sets of
ADV. IP SERVICES
ADVANCED IP SERVICES
Are they the same?
Whats the difference?
Mark Cronin
Hi, when you have to choose an IOS version try to get a GD (General Deploymen, A major release of Cisco IOS Software reaches the "General Deployment" milestone when Cisco feels it is suitable for deployment anywhere in customer networks where the features and functionality of the release are required), so if you don't have a GD at 12.4 use a 12.3 version.
5 Replies 5
icabrera
Level 4
Level 4
Hi, these are exactly the same ADV. is the ADVANCED abbreviation.
At the next url you can see the Cisco IOS packages you can have:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/index.html
Hope this helps, if so pls rate post.
Isabel
When I choose ADV. IP SERVICES for the 877
i get this selection.
12.4.4-XC4 (ED)
12.4.4-XC3 (ED)
12.3.14-YT1 (ED)
And when I choose ADVANCED IP SERVICES
i get these T Stream IOS's apart from
12.4.4-XC5
12.4.11T (ED)
12.4.11-XJ (ED)
12.4.9T2 (ED)
12.4.9T1 (ED)
12.4.9T (ED)
12.4.6T6 (ED)
12.4.6T5 (ED)
12.4.6T4 (ED)
12.4.6T3 (ED)
12.4.6T2 (ED)
12.4.6T1 (ED)
12.4.6T (ED)
12.4.4T7 (ED)
12.4.4T6 (ED)
12.4.4T5 (ED)
12.4.4T4 (ED)
12.4.4T3 (LD)
12.4.4T2 (ED)
12.4.4T1 (ED)
12.4.4T (ED)
12.4.4-XC5 (ED)
12.4.2T5 (ED)
12.4.2T4 (ED)
12.4.2T3 (ED)
12.4.2T2 (ED)
12.4.2T1 (ED)
12.4.2T (ED)
Which one would you choose for a production
environment T XC or YT?
Are you using 12.4 or are you still running 12.3?
Would you use
12.3.14-YT1 (ED)
rather than
12.4.9T2
Hi, if both versions are ED and you don't have another option I'll probably use 12.4.9T2
