IOS Versions and Specs
firastakleh
Hi everyone,
I am preparing for my CCNA, while I am working GNS3 or the real routers or switches some commands are not applied. I did some researches online and found it is the IOS versions that I am using. so can any one give me a brief description for the IOS versions and specs, and which lab routers and switches have full version in general. something else which routers and switches are best to build up a home lab to practice hands-on lab at home
TNX
Ganesh Hariharan
Hi everyone,
TNX
GNS3 simulator is good for practice and traoubleshooting the real time senario, try to use ios for 3800,3700 or 2600 series switch with NME module for switching practice but with limited functionlity.
Hope it Helps
Ganeshh Iyer
Rate if it Helps ...
Hi There,
do not use all the routers in GNS3. use only the 3725 platform with a 12.4T IOS line. It will be more than enough for all CCNA and CCNP scenarios
Alessio
