IOS XE and Port Channel QoS
arudolph_emd
I have a 4510R-E chassis with SUP7-E running IOS XE version 3.01.01.SG.  I am unable to create a port-channel and apply auto-qos for VOIP.
If I configure auto-qos on the physical interfaces, I get this message when I try adding them to the port channel:
"The attached policymap is not suitable for member either due to non-queuing actions or due to type of classmap filters."
Auto-qos is not an available command in the port-channel interface configuration, but if I try adding the service policies that were created by auto-qos to the port channel manually, it lets me apply the input policy but on the output policy I get this message:
"A service-policy with queuing actions can be attached in output direction only on physical ports."
With the input policy applied to the port-channel interface, I tried addign the output policy to the  physical ports and I got this message:
"A service-policy with non-queuing actions should be attached to the port-channel associated with this physical port."
Is there a way to get the auot-qos policies applied to the port-channel properly?
Andy
dominic.caron
Level 5
Level 5
I havent find a way yet. What you need to do is split your policy in two. Take anything related to queuing, put it into a policy and apply it to the physical port. Take the rest and apply it (in another policy) to the port-channel interface.
I have this issue on sup6 also, it's not IOS XE related. Just a annoying little "feature"
dominic.caron
Level 5
Level 5
Thanks for the reply Dominic, that is what I ended up doing to make it work.  I just wish it would stay consistent.  I have an older 4507 chassis with Sup IV and you apply everything on the physical interfaces on that one, nothing to the port-channel interface.
Simon Sigre
In the IOS-XE stream the proper fix for this is apparently due in July this year. Ive been unable to replicate the fix provided (applying tags etc through the physical interface vs port-channel ) ...
Are you sure this works as expected;
For example;
class-map match-any class_icmp
match protocol icmp
policy-map policy_tag-icmp
class class_icmp
  set ip dscp ef
interface Port-channel1
ip address 192.168.1.11 255.255.255.0
interface GigabitEthernet0/0
no ip address
duplex full
speed 1000
media-type gbic
negotiation auto
channel-group 1
service-policy output policy_tag-icmp
Does not have the same effect as applying the "service-policy output policy_tag-icmp" to the port-channel
All of that being said; "QoS for Etherchannel Interfaces" - IOS-XE
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-eth-int.html
