IOS-XE Auto Qos - Warning
Neil Stewart
Hello
Having enabled "auto qos trust" on a 3850-48P, we are seeing the below messages.
*Sep 14 00:49:59.044:  Warning: Modification to policy AutoQos-4.0-Trust-Cos-Input-Policy on wired port is unrecommended, please remove and reapply if unexpected behavior is seen
*Sep 14 00:49:59.044:  Warning: Modification to policy AutoQos-4.0-Output-Policy on wired port is unrecommended, please remove and reapply if unexpected behavior is seen
*Sep
interface GigabitEthernet2/0/3
switchport access vlan 2
switchport mode access
switchport voice vlan 3
auto qos trust
spanning-tree portfast
service-policy input AutoQos-4.0-Trust-Cos-Input-Policy
service-policy output AutoQos-4.0-Output-Polic
The error message appear multiple times when autoqos was applied and also appears multiple times when a port is connected\disconnected ?
See below sample port config
auto qos trust
service-policy output AutoQos-4.0-Output-Policy
Any guidance or explanation would be great.
Richard Primm
Hi Neil,
For the most part, these can safely be ignored.  We see this often and there are a few internal bugs to get these log messages cleaned up. They will most likely be suppressed in 3.3 which is due out in October.
A couple things to remember:
++If this message is seen after  a policy is modified through configuration, it is recommended to detach the policy and re-attach it to ensure that the QOS policy works correctly.
++If this message appears due to interface up/down or speed negotiation, it is okay to ignore it.
Hope that helps.
-Luke
Is it possible to get anyone to confirm this answer as correct? I have a pretty good understanding of QoS and there were no changes to the policy at all, just interface up/downs that triggered the warning about Modification to policy is unrecommended. Thus, I'm inclined to believe your answer because I can't think of any reason why an interface flap would have a real negative impact on marking policies. Can anyone else concur with this answer?
