IP Access-group DNS problems
Adam Coombs
Hello need more help with my project please. I have a vlan inside our network, this vlan can only access a few resources. I was using the big network DNS server for internet access but that has change, they are adding a DC and Exchange server on this vlan. So I need to get the DC to access public dns server like 8.8.8.8 (google).
I can not get this to work
Here is my config
interface Vlan888
 description VLAN 888 - PROJECT test
 ip address 10.88.70.250 255.255.255.0
 ip access-group TEstIN in
 ip helper-address 10.88.70.50
standby 1 ip 10.88.70.254
standby 1 priority 200
standby 1 preempt
standby 1 authentication XXXXX
 Extended IP access list TEstIN
    10 permit ip 10.88.70.0 0.0.0.255 10.88.70.0 0.0.0.255 log
    15 permit ip 10.88.70.0 0.0.0.255 host 10.70.0.1 log
    16 permit ip host 10.70.0.1 10.88.70.0 0.0.0.255 log
    20 permit ip 10.88.70.0 0.0.0.255 10.99.10.0 0.0.0.255 log
    21 permit ip 10.88.70.0 0.0.0.255 10.99.11.0 0.0.0.255 log
    35 permit tcp any any eq www log
    36 permit tcp any any eq 443 log
    37 permit tcp any eq www any log
    38 permit tcp any eq 443 any log
    40 permit tcp any any eq domain log
    41 permit tcp any eq domain any log
    42 permit udp any any eq domain log (1596 matches)
    43 permit udp any eq domain any log
    60 deny ip any any
DC IP config
IP      10.88.70.50
Subnet  255.255.255.0
Gateway 10.88.70.254
DNS 8.8.8.8
you can see i am getting hits on my DNS acl line.
When I try to do a nslookup fails, ping fails.
Please Help
Walter Astori
I think that the DNS traffic tcp and udp can pass but you must add the permit ip any any for icmp
well, i found the issue I was having was with the Firewall that everyone is behind
I just need to allow the DC(ip address) to 8.8.8.8
had to make inside access rule
Tagir Temirgaliyev
where is nat ? you can not go to google dns from local network address
