02-01-2007 07:06 AM - edited 03-05-2019 02:06 PM
I am trying to understand the difference between adding an ACL to an interface with the ip access-group in ip access-group out statement. I have 'in' on one interface, and 'out' on another, and they seem to behave differently. Both of the interfaces end up going out to the internet. A firewall allows the 192.168.3.0/24 range out to the internet. So the 192.168.150.0/24 network gets NAT'd to 192.168.3.100-150 (Overloaded), and the 192.168.3.0/24 interface just keeps the same IP.
See Below:
interface Ethernet1/0
description Lab Network 192.168.150.x
ip address 192.168.150.1 255.255.255.0
ip access-group LAB_ACL in
ip nat inside
full-duplex
ntp disable
<-- cut -->
ip access-list extended LAB_ACL
remark
remark #######################################################
remark
permit ip 192.168.150.0 0.0.0.255 host 4.2.2.1
permit ip 192.168.150.0 0.0.0.255 host 4.2.2.2
permit ip 192.168.150.0 0.0.0.255 65.200.222.0 0.0.0.63
permit ip 192.168.150.0 0.0.0.255 65.200.10.0 0.0.0.255
remark
remark Deny all
deny ip any any log
interface FastEthernet0/1
description Corporate NAT Interface
ip address 192.168.3.2 255.255.255.0
ip access-group ACL_allowed out
ip nat outside
speed 100
full-duplex
<-- cut -->
ip access-list extended ACL_allowed
remark
remark Deny standard microsoft ports
deny tcp any any eq 135
deny tcp any any eq 137
deny tcp any any eq 138
deny tcp any any eq 139
deny udp any any eq 135
deny udp any any eq netbios-ns
deny udp any any eq netbios-dgm
deny udp any any eq netbios-ss
deny tcp any any eq 445
deny udp any any eq 445
remark
remark Permit only traffic with local network
permit ip 192.168.3.0 0.0.0.255 any
remark
remark Deny all
deny ip any any log
Solved! Go to Solution.
02-02-2007 11:12 AM
You're just messing with us now...
Just kidding.
Out would be out of the physical port or onto the wire.
Example 1: IN
Host A -------> fa0/1 fa0/xx -------> Host B
int fa0/1
ip access-group 101 in
-in this scenario Host A would be source when you write your acl, host B would be destination.
-acl would inspect traffic from A to B because traffic is coming "in" the interface where the access-group is applied
Example 1: OUT
Host A <------- fa0/1 fa0/xx <------- Host B
int fa0/1
ip access-group 101 out
-in this scenario Host B would be source when you write your acl, host A would be destination.
-acl would inspect traffic from B to A because traffic is coming "out" the interface where the access-group is applied
Any better?
02-02-2007 12:58 PM
That makes sense. My problem with the whole issue was that traffic still is able to flow back an interface, I just assume that the ACL allows originated traffic back in. If you look at the above config that I had originally posted, it didn't make sense. It seemed that the ACL was backwards, but it was the NAT playing a role. I apologize for all the hassle. I do appreciate this forum, and thank everyone who contributed.
