Ip assignment latency
saborbas
Community Member
I am in need of assistance, Lately I have been noticing a delay when assigning IP address to the PC and laptops on my LAN. The problem might have always been there from the start but since I upgraded all the Pc/laptops on the network to SSD, boot time have been cut to under 10 seconds.  Here is the situation.
IP assignment from my DHCP server takes about 90 Seconds. HD boot about 3min never noticed, SSD boot 10 seconds now we must wait 90 seconds for the IP assignment.  I've upgraded all firmwares (PC/Switch/Router) to the latest versions.
PC are dell OptiPlex, Laptops are Dell Latitudes. All are various models. Router ( DHCP server) is a Sonicwall Tz500, Switches are Cisco SG220's.
If I bypass a switch and jacked directly to the back of the SonicWALL firewall, IP assignment is immediate. Same pc jacked via the cisco switch to Sonicwall, IP assignment take 90+seconds.  Switches/PC are setup with a vanilla config. No Jumbo packets,
Appreciate any help
Sandor
Reza Sharifi
Not familiar with SG series switches but make sure you enable portfast on access ports. Also, check to make sure the spanning tree protocol you are running is the same across all switches.
Don't see portfast anywhere, Spanning Tree set as follows
Spanning Tree Enabled
Operations mode -Classic STP
BPDU handling- Flooding
Path Cost - Long
Priority - Default
Hello Time - Default
Max Age- Default
Forward Time- Default
Any help appreciated
here is the config guide on how to enable it:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf220_sg220/command_line_reference/Sx220_CLI_Guide.pdf
The following example enables the PortFast mode on gi15:
switchxxxxxx(config)# interface gi15
switchxxxxxx(config-if)# spanning-tree portfast
Mark Elsen
 - Check the solving reply from this thread , it looks somewhat 'compatible' and or related to the fact that your PC's are booting much faster now :
        https://community.cisco.com/t5/switching/take-too-much-time-to-get-an-ip-over-a-cisco-switch/td-p/2895550
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
