ip device tracking command in cisco 3750g, not displaying any
apurba
#show ip device tracking all
IP Device Tracking = Enabled
IP Device Tracking Probe Count = 3
IP Device Tracking Probe Interval = 30
IP Address MAC Address Interface STATE
** not showing any ip and mac
ip device tracking maximum 5
% Invalid input detected at '^' marker.
also get invalid input when try to find mac in specific port
Are this issue solved?
6 Replies 6
show ip device tracking interface xxx
try this command to show
nothing displaying
Jitendra Kumar
Enter the ip device tracking maximum 0  Command
This command does not truly disable IPDT, but it does limit the number of tracked hosts to zero. This is not a recommended solution and it must be used with caution, because it affects all of the other features that rely on IPDT, which includes the port-channels configuration as described in 'Cisco bug ID CSCun81556'.
Turn Off Active Features that Trigger IPDT
Some features that can trigger IPDT include NMSP, device sensor, dot1x/MAB, WebAuth, and IPSG.  These features shoudl not be enabled on trunk ports. This solution is reserved for the most difficult or complex situations, where either all of the solutions previously available did not work as expected, or they created additional problems. This is, however, the only solution that allows extreme granularity when you disable IPDT, because you can turn off only the IPDT-related features that cause problems and leave everything else unaffected.
In the most recent Cisco IOS, Versions15.2(2)E and later, you see an output similar to this:
Switch#show ip device tracking interface GigabitEthernet 1/0/9
Interface GigabitEthernet1/0/9 is: STAND ALONE
IP Device Tracking = Disabled
IP Device Tracking Probe Interval = 180000
IPv6 Device Tracking Client Registered Handle: 75
IP Device Tracking Enabled Features:
HOST_TRACK_CLIENT_ATTACHMENT
HOST_TRACK_CLIENT_SM
Jitendra
apurba
got my solution for 3750G, i also attached the config process
yeah issue is resolved.
