12-11-2010 07:47 PM - edited 03-06-2019 02:29 PM
Hi all,
I have question regarding using ip dhcp snooping trust command.
Here is network
3550 Layer 3 switch with config as shown
ip dhcp snooping vlan 10,20,30
ip dhcp snooping
DHCP snooping is configured on 3550 switch.
Interface fa0/8 from this switch goes to layer 2 switch 2950
3550SMIA#sh run int fa0/8
Building configuration...
Current configuration : 213 bytes
interface FastEthernet0/8
description Dynamic Desirable Trunk connection to Switch 2950T
switchport mode dynamic desirable
speed 100
duplex full
spanning-tree bpduguard disable
ip dhcp snooping trust*************************************************
As shown above i config the trunk interface fa0/8 as ip dhcp snooping trust on layer 3 switch.
Also 3550 switch is acting as DHCP server *******************************************
Now Layer 2 switch config
DHCP snooping is enabled as shown below
ip dhcp snooping
Port fa0/8 from 2950 layer 2 goes to 3550 switch
My question is
should i use command ip dhcp snooping trust************************************************* on port fa0/8 on layer 2 switch or not ?
if someone can explain we if my dhcp snooping config is correct or not?
thanks
mahesh
12-11-2010 11:54 PM
the ip dhcp snooping trust must be configured on links going to your dhcp server.
So if your 3550 is your dhcp server I would get rid of dhcp snooping on it and I would leave trust on 2950 port pointing towards 3550 but I would do snooping for all vlan scopes configured on 3550.
Regards.
Alain.
12-12-2010 01:55 AM
thanks for reply
so on 3550 switch i can remove the ip dhcp config trust from fa0/8 interface ?
mahesh
12-12-2010 05:52 AM
thanks for reply
or you want me to remove config ip dhcp globally?
mahesh
12-12-2010 09:11 AM
You only need to configure dhcp snooping on switches pointing towards your dhcp server.
The purpose of this feature is to stop dhcp server messages on ports pointing towards clients and by default the ports are untrusted
you must then trust ports uplink to your dhcp server.
So yes if this 3550 is the only dhcp server then no need for dhcp snooping on it.
Regards.
Alain.
12-13-2010 09:57 PM
hi cadetalain
it did not work as you said.
here is info
layer 2 switch has uplink port to layer 3 3550 switch
layer 2 switch trunk port is config as ip dhcp snooping trust.
layer 3 switcs 3550 trunk port to layer 2 switch do not have ip dhcp snooping trust command.
i plug my pc to layer 2 switch and it did not get the ip address from layer 3 switch which is acting as dhcp server.
i got ip 169.254.
fix
when i config the command
ip dhcp snooping trust on layer 3 switch's trunk port going to layer 2 switch then my pc got the IP address.
thanks
mahesh
