ip-dhcp
edondurguti
Level 4
Level 4
Did anyone have this issue before:
I dont have any access list - it's just a generic router that I'm trying to get an ip address from.
My router is 871
*Mar  1 01:13:51.367: DHCP: SDiscover: sending 270 byte length DHCP packet
*Mar  1 01:13:51.367: DHCP: SDiscover 270 bytes
*Mar  1 01:13:51.367:             B'cast on FastEthernet4 interface from 0.0.0.0
*Mar  1 01:13:51.575: DHCP: Received a BOOTREP pkt
*Mar  1 01:13:51.575: DHCP: Scan: Message type: DHCP Offer
*Mar  1 01:13:51.575: DHCP: Scan: Server ID Option: 192.168.10.1 = C0A80A01
*Mar  1 01:13:51.575: DHCP: Scan: bad Host name string Option len 0
*Mar  1 01:13:51.575: DHCP: Error in pkt. punting
*Mar  1 01:13:55.367: DHCP: SDiscover attempt # 3 for entry:
*Mar  1 01:13:55.367: Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet4
*Mar  1 01:13:55.367: Temp  sub net mask: 0.0.0.0
*Mar  1 01:13:55.367:    DHCP Lease server: 0.0.0.0, state: 3 Selecting
*Mar  1 01:13:55.367:    DHCP transaction id: 11B8
*Mar  1 01:13:55.367:    Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
*Mar  1 01:13:55.367:    Next timer fires after: 00:00:04
*Mar  1 01:13:55.367:    Retry count: 3   Client-ID: 0019.2f41.1c77
*Mar  1 01:13:55.367:    Client-ID hex dump: 00192F411C77
*Mar  1 01:13:55.367:    Hostname: Router
*Mar  1 01:13:55.367: DHCP: SDiscover: sending 270 byte length DHCP packet
*Mar  1 01:13:55.367: DHCP: SDiscover 270 bytes
*Mar  1 01:13:55.367:             B'cast on FastEthernet4 interface from 0.0.0.0
*Mar  1 01:13:55.575: DHCP: Received a BOOTREP pkt
*Mar  1 01:13:55.575: DHCP: Scan: Message type: DHCP Offer
*Mar  1 01:13:55.575: DHCP: Scan: Server ID Option: 192.168.10.1 = C0A80A01
*Mar  1 01:13:55.575: DHCP: Scan: bad Host name string Option len 0
*Mar  1 01:13:55.575: DHCP: Error in pkt. punting
*Mar  1 01:13:59.367: DHCP: QScan: Timed out Selecting state
john kennedy
Can you post all of the configuration you have for DHCP and also the interface? I have several 871s that I have run DHCP on in the past and I have never had this issue.
