IP flow monitor output
t-van
I tried to issue command ip flow monitor ..... output on a trunk interface on switch 2960x, but it errrored out with could not be added to interface due to invalid sub-traffic type: 0.  We have a Cisco One license and running on c2960x-universalk9-mz.152-5.E2.bin.  Does anyone experience with this error and how to fix it?  or the switch just doesn't support the output?  Thanks all.
Reza Sharifi
This link refers to 4500 series but the same limitation may also  may apply to the 2960x series
https://www.lancope.com/wiki/cisco-catalyst-4500x
6 Replies 6
Mark Malone
you tried to add ip flow a layer 3 command to a layer 2 trunk port , it needs to be added to the vlan svi interface on a latyer 2 switch or else use the
As well if your trying to collect layer 2 fields make sure the specific mac fields are in place
Thanks.  Basically the output command can't be issue on a interface alone.
Reza Sharifi
This link is not function :-( i have similar problem on C2960X IOS 15.2.4.E7
Whats the problem your having ?
% Flow Monitor: 'MonitorTest' could not be added to interface due to invalid sub-traffic type: 0
spoken about 2960X switches. I have same problem that explained above
