IP Helper on WAN/LAN
Rodrigo Gurriti
Level 3
Level 3
I have the scenario attached, this scenario the wan is frame-relay
My question is how can a DHCP server remote identify what POOL of IP address to use?
I know I can use a local dhcp server, even the router as dhcp server,  but the centralized dhcp is a requirement :/
2 Accepted Solutions
paolo bevilacqua
It know because the router insers GW address in the request packet.
Be aware that when WAN is down, the "requirement" becomes a major hinderance, and everyone gets very angry.
i think attached document will provide you more information
http://h40060.www4.hp.com/procurve/uk/en/pdfs/5300xl_dhcp_relay.pdf
Shailesh
paolo bevilacqua
For instance,
Will F1 forward the dhcp discovery from a workstation to the DHCP server using as source address F1's local ethernet? Is that how it knows ? or is there a option that it uses ?
Thank you!
Shailesh
Thanks for the help...
I found also these documents very useful
http://www.freesoft.org/CIE/RFC/2131/20.htm
http://www.tarunz.org/~vassilii/TAU/protocols/dhcp/frame.htm
They confirm what shailesh said above
