IP helper problems
marshallqqqq
Community Member
I can't get IP Helper to work on my network. Setup:
Client Pc <> 2950 <> 3560 <> Server 2003
Client PC: Dhcp
2950:
vlan 2
name Management/Secretariaat
vlan 3
name DC
vlan 4
name Servers
vlan 5
name ICT
interface Vlan2
no ip address
no ip route-cache
shutdown
interface Vlan3
no ip address
no ip route-cache
shutdown
interface Vlan4
no ip address
no ip route-cache
shutdown
interface Vlan5
ip address 192.168.5.15 255.255.255.0
ip helper-address 192.168.4.6
no ip route-cache
interface FastEthernet0/1 # to client pc
switchport access vlan 3
switchport mode access
interface GigabitEthernet0/1 # to the 3560
switchport trunk allowed vlan 2-5
switchport mode trunk
3560:
vlan 2
vlan 3
name DC
vlan 4
name Servers
vlan 5
name ICT
interface Vlan2
description Management/Secretariaat
ip address 192.168.2.2 255.255.255.0
interface Vlan3
ip address 192.168.3.2 255.255.255.0
interface Vlan4
ip address 192.168.4.2 255.255.255.0
interface Vlan5
ip address 192.168.5.2 255.255.255.0
interface GigabitEthernet0/1 # naar de 2950
spanning-tree link-type point-to-point
interface GigabitEthernet0/13 # to windows 2003 dhcp server
switchport access vlan 4
windows 2003
Own ip: 192.168.4.6
dhcp scopes for 192.168.2.x 3.x 4.x 5.x
Notes:
-I can ping from the 2950 to the windows 2003 dhcp server
-dhcp does work if i configure the client port in vlan 4 (dhcp server is also located in this subnet)
-windows server shows up in the mac table of  the 2950
Jon Marshall
The 2950 switch is a L2 switch only so the vlan 5 interface on the 2950 switch is only used for managing the switch ie. it is not used for client traffic.
You need to add the ip helper-address to the vlan 5 interface on the 3560 instead ie.
interface Vlan5
Also the client default-gateway must be the vlan 5 address on the 3560 ie. 192.168.5.2 and not the vlan 5 address on the 2950 ie. 192.168.5.15 so you may need to update your DHCP scope on the windows server.
Jon
Jon Marshall
interface Vlan5
Jon
Thanks for the fast reply!
