IP Multicast on Cat2960 issue
Wolfgang Maier
Hi @all,
I have a weird multicast problem.
I´ve  setup multicast routing in our network.
Multicast is working so far but the Receivers attached to the Catalist 2960 Switches receive the stream in a very poor quality (pixel images, distorted sound, choppy image flow)
The Source is a VLC Stream to the group 239.193.0.1 with a TTL=12 . However the same stream on the same VLAN only on a Catalyst 3560 or 2950 is playing smoothly. Based on this information, I think there´s something wrong at the 2960 end but I can´t fugure what. igmp snooping is active and I can see the mroute and querier.
I had a look at the network utilization and on the receivers where the stream is working (attached to 3560/2950) have a network utilization of around 1Mbit/s The other receiver where the stream is choppy the network stream is around 4Mbit/s....weird.
Can someone help me out? Thank you
7 Replies 7
Wolfgang Maier
Now I´ve found out that if I connect the 2960 Switch to the 3560CX switch streaming works *confused*
Hello Christian,
This issue is confusing indeed.
One thing, though: Can you confirm that when you had your 2960-PST connected directly to the SiteB switch, all ports on the 2960-PST and the corresponding port on the SiteB switch were operating at at least 100 Mbps, full duplex? Are you configuring any of these parameters (speed and/or duplex) manually at any point in your network?
Best regards,
Peter
Good day Peter,
thank you for your reply. Yes, the trunk ports are all 1Gbit/s and the ports towards the receivers are 100Mbit/s.
I also noticed a lot of drops on the interfaces towards the receivers but only when the 2960-PST is directly connected to the 6509-V-E (Site B)
FastEthernet0/2 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 6899.cd3d.ad82 (bia 6899.cd3d.ad82)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 12/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1772366
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 4992000 bits/sec, 454 packets/sec
     5666 packets input, 747531 bytes, 0 no buffer
     Received 1479 broadcasts (1108 multicasts)
     0 watchdog, 1108 multicast, 0 pause input
This drops are constantly increasing which would explain the bad quality of the stream. But why are these packets dropped?
I thought OK, lets check the core switch there must be something. And here is what i found out :
IP statistics:
  Rcvd:  2032682421 total, 574453407 local destination
         0 format errors, 0 checksum errors, 40270311 bad hop count
         6 unknown protocol, 528722 not a gateway
         0 security failures, 0 bad options, 8527652 with options
  Opts:  4 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 4 record route
         0 stream ID, 0 strict source route, 8527648 alert, 0 cipso, 0 ump
         0 other
  Frags: 3 reassembled, 0 timeouts, 0 couldn't reassemble
         2213 fragmented, 0 couldn't fragment
  Bcast: 115203121 received, 3150421 sent
  Mcast: 22500620 received, 20975346 sent
  Sent:  630567240 generated, 1135212704 forwarded
  Drop:  78437506 encapsulation failed, 0 unresolved, 0 no adjacency
         3172490 no route, 0 unicast RPF, 0 forced drop
         0 options denied, 0 source IP address zero
This counter is increasing also. But this would mean that the multicast stream has a TTL issue. On the source I´ve double checked  VLC. These are the stream options
:sout=#rtp{dst=239.193.0.1,port=5004,mux=ts,ttl=12} :sout-all :sout-keep
If there is indeed a TTL issue, why does the stream work flawlessly on a 2950 and 3560 ?
I dont have any clues.
Best regards,
Christian
To exclude any issues with TTL I´ve measured the multicast traffic on Site B:
All packets are send with a ttl value of 10.. so this wouldn´t be a issue
This really is confusing.
Is all the routing for vlans done on the 6500s ?
When you see the problems what do unicast pings show ie. do you also see higher response times via that switch ?
When you have the 2960 directly connected what do -
"sh ip igmp snooping groups"
"sh ip igmp mrouter"
show and is there any difference in the outputs when you connect via the 3560.
Jon
Hi Jon,
yes, routing is done on the 6509. The pings from and to the receiver are all <1ms no packet loss.
Here is the output from the 2960:
Vlan      Group                    Type        Version     Port List
250       239.193.0.1              igmp        v2          Fa0/1, Gi0/3
250       239.255.255.250          igmp        v2          Fa0/1, Gi0/3
Gi0/3 is the trunk to the 6509
sh ip igmp mrouter isn´t available as this are L2 switches.
I get the same output on the 3560/2950
Christian
One step further: thanks to our nice support tech who suggested to set the trunk from 1Gbit/s to 100Mbit/s.
Now, with a 100Mbit/s Trunk all drops on the int fa0/1 dissapeared and the multicast stream works as expected.
The total bandwith of the stream on that trunk interface is 5 Mbit/s  (avarage) so this can only be a buffer problem.
