IP over FC on Catalyst 3750(G) possible?
We have a 3750 and a 3750G switch with 4 FC ports each. Is it possible to configure these ports for TCP/IP over Fibre Channel?
Thanks in advance,
Torkil
cfolkerts
The 3750 fiber ports are only used for Ethernet.  They do not support Fibre Channel or FCIP.  You will need an MDS switch like the 9222i to support FCIP.
aaraaz747
Or you can get Nexus 5000 - you'll get FC and ethernet
