IP Overlapping - Who can help me understand
techspec01
Hi, currently doing a lab in PT. Getting the following error message:
FIRST Router(config)#interface Fastethernet0/0
Router(config-if)#ip add 172.16.0.1 255.255.240.0
Router(config-if)#exit
SECOUND Router(config)#interface Fastethernet0/0
Router(config-if)#ip add 172.16.0.2 255.255.240.0
Now I'm trying to connect the SECOND router to a THRID router:
Router(config)#interface Fastethernet1/0
Router(config-if)# ip add 172.16.0.17 255.255.240.0
% 172.16.0.0 overlaps with FastEthernet0/0
Since the CIDER is /30 isn't the magic number 16?
172.16.0.0 to 172.16.0.15
172.16.0.16 to 172.16.0.31
Wouldn't 172.16.0.17 be a valid IP address for 2nd Router Fa1/0?
Can you please help me understand what I'm missing? thank you
omz
CIDR for 255.255.240.0 would be /20
172.16.0.1 255.255.240.0 gives you 172.16.0.1 - 172.16.15.254
172.16.0.1 255.255.255.240 gives you 172.16.0.0 - 172.16.0.15
the MAGIC number you are referring to would map to the octet ..
255.255.255.240 = / 28
172.16.0.16 - 172.16.0.31
172.16.0.32 - 172.16.0.47
255.255.240.0 = /20
172.16.0.0 - 172.16.15.254
172.16.16.0 - 172.16.31.254
172.16.32.0 - 172.16.47.254
Richard Burts
I am not clear about this statement
How did you believe that the CIDER is /30? The mask for /30 is 252. And for /30 the magic number is not 16.
Using 172.16.0.17 would work if the mask you were using was 255.255.255.240 but you are using mask 255.255.240.0. With that mask you have addresses beginning at 172.16.0.1 through 172.16.15.255
Rick
omz
255.255.240.0 = /20
