Ip overlaps Cisco packet tracer
victor703
I have a problem when I want to connect my router to multiple access points it doesn't work.
In this case, I am replicating a file network, so just adjusting something doesn't really work.
For the access points, I need to use the following ip addresses:
192.168.1.31
192.168.1.30
192.168.26
if i now want to configure all three of these in the router's ports, i get the message that it overlaps
Mark Elsen
                    - FYI : Community group for Packet Tracer project questions
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Martin L
First 2 will give u overlaping error when configured on the same router with the same subnet; You should use so called VLSM - variable subnet mask; i.e. 192.168.26.x /24 and 192.168.1.x/24 are ok but not 192.168.1.30/24 and 192.168.1.31/24;
Regards, ML
**Please Rate All Helpful Responses **
