IP Routing Error!
adamgreenwood14
For some reason nothing is being routed on my router in the cisco packet tracer.
I have been researching online and I have realised that I need to enable IP Routing, is this the problem? Although when I followed instructions online, this is what happens:
Router1#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router1(config)#ip routing
% Invalid input detected at '^' marker.
Here is my router config:
Current configuration : 1127 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
enable password class
interface FastEthernet0/0
ip address 192.168.20.62 255.255.255.192
duplex auto
speed auto
interface FastEthernet1/0
ip address 192.168.20.94 255.255.255.224
duplex auto
speed auto
interface FastEthernet2/0
ip address 192.168.20.126 255.255.255.224
duplex auto
speed auto
interface FastEthernet3/0
ip address 192.168.20.158 255.255.255.224
duplex auto
speed auto
interface FastEthernet4/0
ip address 192.168.20.166 255.255.255.248
duplex auto
speed auto
interface FastEthernet5/0
ip address 192.168.20.174 255.255.255.248
duplex auto
speed auto
interface FastEthernet6/0
ip address 192.168.20.182 255.255.255.248
duplex auto
speed auto
interface Serial7/0
ip address 192.168.20.185 255.255.255.252
router rip
ip classless
banner login ^C Welcome to the router! ^C
line con 0
line vty 0 4
password class
login
end
Any help would be greatly appreciated!
Adam
IP routing is enabled by default, it's a router...
Explain exactly what your problem is, and what isn't working.
Ryan Wolfe
Level 5
Level 5
You need to enable the RIP process with you interfaces. Put in the network commands for each interface's network. That's my first guess.
network (network address)
Also, ip routing is enabled by default on routers.
Andrew Cink
Are there devices plugged in to those ports on the router? If the interface is down, it won't do anything... show interface status?
