ip routing for cisco ME-3400G-2cs??
ciscozan2008
please!
do a switch cisco ME-3400G-2cs support ip routing?
can a switch cisco ME-3400G-2cs support inter-vlan routing in a LAN??
2 Accepted Solutions
"Routing is supported only on switches that are running the metro IP access image".
Reference:http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_44_se/configuration/guide/swiprout.html
I hope this helps.
Best regards.
Massimiliano.
satish_zanjurne
Level 4
Level 4
I hope this helps.
Best regards.
Massimiliano.
satish_zanjurne
Level 4
Level 4
HI ,
It does support IP routing & inter-vlan routing.
http://www.cisco.com/en/US/prod/collateral/switches/ps6568/ps6580/product_data_sheet0900aecd8034fef3.html
HTH..
rate if helpful
