IP routing on 887
info00700
We are getting an 887 with our new fibre internet connection along with a set of public ip addresses. Internally we use private ips on the LAN. How can we route the public ips to our private ips within the 887 router?
Attached is how we are doing it on our current router.
Joseph W. Doherty
NAT
Hi Joseph
This is a managed router by the ISP and they say it wont provide NAT. Any other option?
If it's an ISP managed router, then why doesn't your ISP offer a solution?  If they are unwilling, maybe you should consider another ISP.
That aside, you could by your own device, provide NAT between your internal private IPs and one of the public IPs.  I assume your ISP will route to the public IPs they're providing.
