IP SLA - not logging plus additional questions
jacob6000
I configured an IP SLA HTTP test and it appears to be working but it is not logging via syslog (or sh log) and it is not sending traps.  My code is 124-24.T3 on a 2801 router.
1) What do I need to change to  enable logging of my IP SLA results, etc.?
2) What does the "Operation time to live: 2013 sec" value mean? Typically it says "Forever" but this one has a countdown when the threshold isn't  met? What is the countdown for?
config and output
logging trap debugging
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server host 192.168.1.125 version 2c <hidden>  ipsla syslog
ip sla responder
ip sla logging traps
ip sla 80
http get http://www.google.com name-server 8.8.8.8
timeout 2000
threshold 200
owner mobiusadmin
tag Google website
frequency 120
ip sla schedule 80 start-time now
ip sla reaction-configuration 80 react timeout threshold-type immediate action-type trapOnlyip sla responder
Thank you,
jacob6000
My fault. I left of the "life forever" parameter which is why the operation defaults to 3959 seconds or something like that.
As for the logging, I was hoping to capture these stats somehow via syslog but I don't think it's possbile.
