IP SLA on 4948 Platform
efairbanks
Can somebody confirm that IP SLA functionality exists on a 4948 switch running 12.2(50)SG3 Enterprise?  The feature navigator shows it in there, and the release notes for the 4500 chassis says it is supported, but I am having trouble finding documentation confirming that it is supported in the 4948 platform.  Little concerned...
Thanks in advance for any assistance provided.
-Erik
Antonio Knox
Level 7
Level 7
Here you can find the Configuration Guide for 12.2(50)SG
http://www.cisco.com/en/US/products/ps6021/products_installation_and_configuration_guides_list.html
Once you've clicked the Configuration guide link, look towards the bottom of the links to the left and there you should see "Configuring Cisco IOS IP SLAs Operations".
Hope this resolves your issue.
