IP SLA SG350X
Lluis Puig
I'm trying to configure IP SLA with a track for modify routing table in our cisco SG350X.
I don't find this feature using cli:
CISCO(config)#ip ?
  access-list          This command creates an ACL, which perform
                       classification on layer 3 fields and enters ip-access
                       configuration mode.
  arp                  ARP configuration commands
  default-gateway      Specify default gateway
  dhcp                 IP DHCP client commands
  domain               IP Domain Naming System
  helper-address       Specify a destination address for UDP broadcasts
  host                 To define static host name-to-address mapping in the
                       host cache
  http                 Specify the HTTP server configuration
  https                HTTPS server configuration
  igmp                 IGMP interface commands
  igmp-proxy           IGMP proxy configurations
  multicast-routing    To enable IP multicast routing
  name-server          To set the available name servers, use the ip
                       name-server global configuration command.
  route                Establish static routes
  routing              Enable IP routing
  source-guard         IP source-guard configuration
  ssh                  Global Secure Shell protocol configuration subcommands
  ssh-client           secure shell client.
  telnet               Telnet server configuration
Someone know if IP SLA is able to use with this switch?
Thanks in advance,
Lluís P.
0 Replies 0
