IP SLA up and down
athikom.ch
I have issue  about  config IP SLA
This's Here my config ip sla
track 3 ip sla 3 reachability
ip sla 3
icmp-echo 8.8.8.8 source-ip 172.16.1.1
timeout 20000
threshold 15000
ip sla schedule 3 life forever start-time now
But I seeing show logging. It has  logging IP SLA up and down  always
Jun 27 10:29:26.451: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:30:06.580: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:31:26.780: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:32:06.850: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:33:27.032: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:34:07.145: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:35:27.335: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:36:07.473: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:37:27.647: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:38:07.742: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:39:27.925: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:40:08.071: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:41:28.228: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:42:08.332: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:43:28.514: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:44:08.660: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:45:28.826: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:46:08.913: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:47:29.104: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:48:04.183: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:49:24.382: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
Jun 27 10:50:04.494: %TRACKING-5-STATE: 3 ip sla 3 reachability Down->Up
Jun 27 10:51:24.685: %TRACKING-5-STATE: 3 ip sla 3 reachability Up->Down
I have question
if you view my config
I understood  if icmp  reply over 20000 ms [Is 20 Sec]  The object track 3  will  state change up > down
but I tried test  ping ip to destination from notebook is similar SLA 3  , it not time out
I don't  understand about   command timeout IP SLA...
Thank for a lot  answer.
Julio E. Moisa
Where you have applied the track 3? try to remove:
timeout 20000
threshold 15000
And just configure
Frecuency <seconds>
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio
  I track sla 3 on static route  only
and I remove config  timeout and  threshold
This'is currently   config now
ip sla 3
frequency 90
and I will monitor logging by tomorrow
So why i input command  timeout   a lot .the time it's still  down
I would like to  know  the reason this case.
thank
It sounds good, i think 90 seconds is very high, the frequency could be between 5 and 20 seconds, the timeout parameter is used to wait for a reply in miliseconds.
