ip verify unicast reverse-path
cisco_lite
On a router and ASA firewall, should RPF be enabled on all the given interfaces.
2 Accepted Solutions
Jon Marshall
You should generally apply it at the exit point to your network because within your network you may well have asymmetrical paths. Have a look at this doc which goes into where Unicast RPF should be used -
http://www.cisco.com/en/US/docs/ios/11_1/feature/guide/uni_rpf.html#wp1042716
Jon
This is my understanding as well.
6 Replies 6
mikegrous
Level 3
Level 3
typically youd only apply it on your WAN interface as you should be trusting your LAN routes
Jon Marshall
Jon
What is difference between
and
ip verify unicast source reachable-via any
What is the default Unicast RPF mode; loose or strict.
Regards.
In reguard to the first question:
R8(config-if)#ip verify unicast ?
reverse-path Reverse path validation of source address (old command format)
source Validation of source address
From this I understand that both of the above commands have the same effect, where in reverse-path is an old command.
Please confirm.
