ip vrf receive command problem
Luca Tortiglione
Frequent Visitor
Frequent Visitor
Good morning,
I need to insert a route in the general routing table and in a VRF.
Reading on Internet,
I thought to use ip vrf receive command on the interface.
this is CS router :
hostname CS
boot-start-marker
boot-end-marker
ip cef
ip vrf VTC
interface Loopback1021030
ip vrf receive VTC
ip address 10.210.3.1 255.255.255.255
ip policy route-map PC_TO_VTC
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
ip vrf receive VTC
ip address 10.210.0.6 255.255.255.252
speed auto
full-duplex
ip forward-protocol nd
ip route vrf VTC 10.208.0.0 255.255.255.0 10.210.0.5
no ip http server
no ip http secure-server
access-list 100 permit ip 10.210.3.0 0.0.0.255 10.208.0.0 0.0.0.255
access-list 100 permit ip 10.208.0.0 0.0.0.255 10.210.3.0 0.0.0.255
access-list 100 permit ip 10.210.0.0 0.0.0.255 10.208.0.0 0.0.0.255
access-list 100 permit ip 10.208.0.0 0.0.0.255 10.210.0.0 0.0.0.255
route-map PC_TO_VTC permit 1
match ip address 100
set vrf VTC
and this is border router :
hostname Border_VTC
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip vrf VTC
interface Loopback1
ip vrf forwarding VTC
ip address 10.208.0.1 255.255.255.255
ip address 10.210.0.2 255.255.255.252
duplex auto
speed auto
ip address 10.210.0.5 255.255.255.252
speed auto
full-duplex
ip route vrf VTC 10.210.3.0 255.255.255.0 10.210.0.6
Trying to ping I have
CS#ping vrf VTC 10.208.0.1 source fastEthernet 0/1
Sending 5, 100-byte ICMP Echos to 10.208.0.1, timeout is 2 seconds:
Packet sent with a source address of 10.210.0.6
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/100/189 ms
CS#
*Mar  1 00:08:13.404: ICMP: echo reply rcvd, src 10.208.0.1, dst 10.210.0.6
*Mar  1 00:08:13.593: ICMP: echo reply rcvd, src 10.208.0.1, dst 10.210.0.6
*Mar  1 00:08:13.673: ICMP: echo reply rcvd, src 10.208.0.1, dst 10.210.0.6
*Mar  1 00:08:13.749: ICMP: echo reply rcvd, src 10.208.0.1, dst 10.210.0.6
*Mar  1 00:08:13.813: ICMP: echo reply rcvd, src 10.208.0.1, dst 10.210.0.6
CS#ping vrf VTC 10.208.0.1 source Loopback1021030
Packet sent with a source address of 10.210.3.1
On this failed ping i get
Border_VTC#
*Mar  1 00:08:33.810: ICMP: echo reply sent, src 10.208.0.1, dst 10.210.3.1
*Mar  1 00:08:35.757: ICMP: echo reply sent, src 10.208.0.1, dst 10.210.3.1
*Mar  1 00:08:37.764: ICMP: echo reply sent, src 10.208.0.1, dst 10.210.3.1
*Mar  1 00:08:39.752: ICMP: echo reply sent, src 10.208.0.1, dst 10.210.3.1
*Mar  1 00:08:41.767: ICMP: echo reply sent, src 10.208.0.1, dst 10.210.3.1
Trying ping on other router i get
Border_VTC#ping vrf VTC 10.210.3.1 source fastEthernet 0/1
Sending 5, 100-byte ICMP Echos to 10.210.3.1, timeout is 2 seconds:
Packet sent with a source address of 10.210.0.5
Success rate is 0 percent (0/5)
Border_VTC#ping vrf VTC 10.210.3.1 source loopback 1
Packet sent with a source address of 10.208.0.1
Border_VTC#
Any suggestion ?
0 Replies 0
