IPMP with cisco
joaquin386
Does cisco support the in.rdisc protocol from the Solaris OS? If so which ones are the commands.
ebreniz
Level 6
Level 6
I think you should have to the Cisco BTS 10200 Softswitch application software installed on the system.
Execute the following command:
/usr/sbin/in.rdisc -s -f
if [ -f /usr/sbin/in.routed ];
then
\mv -f /usr/sbin/in.routed /usr/sbin/in.routed.org
