07-13-2016 01:12 PM - edited 03-08-2019 06:37 AM
Router6#show interfaces tunnel 1
Tunnel1 is up, line protocol is down
Hardware is Tunnel
Internet address is 192.168.204.6/30
MTU 17940 bytes, BW 100 Kbit/sec, DLY 50000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel linestate evaluation down - linestate mode reg down
Tunnel source 192.70.191.15 (GigabitEthernet0/1), destination 174.47.40.66
Tunnel Subblocks:
src-track:
Tunnel1 source tracking subblock associated with GigabitEthernet0/1
Set of tunnels with source GigabitEthernet0/1, 1 member (includes iterators), on interface <OK>
Tunnel protocol/transport IPSEC/IP
Tunnel TTL 255
Tunnel transport MTU 1500 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Tunnel protection via IPSec (profile "KORE_IPSEC_Profile")
Last input 5d00h, output 1d15h, output hang never
Last clearing of "show interface" counters 6d04h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
Queueing strategy: fifo
Output queue: 0/0 (size/max)
1 packets input, 94 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
83 packets output, 10064 bytes, 0 underruns
0 unknown protocol drops
crypto keyring KOREkeyring
pre-shared-key address 174.47.40.66 key XYZ
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp profile KORE_ISKMP_Profile
keyring KOREkeyring
match identity address 174.47.40.66 255.255.255.255
crypto ipsec transform-set KOREVPN_TRANS esp-aes 256
mode tunnel
crypto ipsec profile KORE_IPSEC_Profile
set transform-set KOREVPN_TRANS
set pfs group2
set isakmp-profile KORE_ISKMP_Profile
As soon as I apply profile to tunnel, tunnel goes down and when tunnel comes up , I can not ping across.
07-13-2016 01:40 PM
Hello Shraddha,
Do you have reachability between 2 Tunnel interfaces ?
Can you also share Tunnel config from the destination.
Harsha
07-13-2016 02:08 PM
interface Tunnel608
description Wi-Tronix Primary Site
ip address 192.168.204.5 255.255.255.252
ip mtu 1400
tunnel source 174.47.40.66
tunnel destination 192.70.191.15 -----> Router06)
tunnel protection ipsec profile P2P_IPSec/GRE_Customers
Jul 13 19:40:19.295: %CRYPTO-5-IKMP_SETUP_FAILURE: IKE SETUP FAILED for local:174.47.40.66 local_id:174.47.40.66 remote:192.70.191.15 remote_id:192.70.191.15 IKE profile:None fvrf:None fail_reason:Proposal failure fail_class_cnt:2
Jul 13 19:41:19.707: %CRYPTO-5-IKMP_SETUP_FAILURE: IKE SETUP FAILED for local:174.47.40.66 local_id:174.47.40.66 remote:192.70.191.15 remote_id:192.70.191.15 IKE profile:None fvrf:None fail_reason:Proposal failure fail_class_cnt:2
ul 13 19:45:46.950: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Jul 13 19:45:46.950: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Jul 13 19:45:46.966: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 174.47.40.66
Jul 13 19:45:47.962: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
Jul 13 19:47:08.361: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 174.47.40.66
Jul 13 19:47:11.009: %SYS-5-CONFIG_I: Configured from console by shraddha.pajwani on vty0 (10.4.4.73)
Jul 13 19:49:08.721: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 174.47.40.66
Jul 13 19:50:09.137: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 174.47.40.66
07-13-2016 02:08 PM
Can you change the MTU on your end to 1400 as well.
07-13-2016 02:30 PM
It is now set to 1400 , however no change in tunnel status.
07-13-2016 02:41 PM
I believe the IKE and IPSEC parameters are not matching on both peer sides.
Kindly compare the config on both ends.
-Harsha
07-13-2016 02:57 PM
I don't have access to remote end. My end suppose to setup as below.
07-13-2016 02:57 PM
Based on your config,
encr 3des
group 2
lifetime 3600
I think you have configured isakmp lifetime as 3600 instead of 86400
Also your requirement says PFS should not be enabled but your config has pfs enabled.
set pfs group2
Please check it from your end and then clear the IKE and IPSEC sessions.
-Harsha
07-14-2016 12:05 PM
Thank you for help. Problem has fixed.
07-14-2016 12:18 PM
Awesome!!! Were you able to correct the config on your end ?
