IPSECISSUE CISCO ASA 5505
yogesh1
CISCO ASA 5505 IPSEC CONFIG
Dear Team,
I am configuring IPSEC on my cisco ASA 5505 & below is template.
After configuration i am unable to see output of command sh crypto isakmp sa.
When i notice the whole configuration when i configure below crypto isakmp policy 300
please note:
On the remote side still configuration is pending & not started yet.
commands:
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
on cli it did not give any error but when i do sh run its not visible on sh run output.
Unable to understand why i am not able to see isakmp policy even after configuration.
Please find the template below & also i did not found output for sh crypto isakmp sa for designated peer IP else i am able to see the status of other IPSEC tunnels.
TEMPLATE:
STEP 3rd
object-group network WH
network-object 10.101.X.X 255.255.XX.XX
STEP 4th
access-list CRYPTO-ASA extended permit ip object-group PMMAF-SA object-group WH
STEP 5th
access-list CRYPTO_NAT extended permit ip object-group PMMAF-SA object-group WH
STEP 6th//**
crypto ipsec transform-set WHH esp-3des esp-md5-hmac
STEP 7th
crypto map MAP 300 match address CRYPTO-ASA
crypto map MAP 300 set peer 165.XX.XX.XX
crypto map MAP 300 set transform-set WHH
crypto map MAP 300 set security-association lifetime seconds 28800
crypto map MAP 300 set security-association lifetime kilobytes 4608000
STEP 1ST
encryption 3des
hash md5
group 2
lifetime 86400
STEP 2nd
isakmp keepalive threshold 15 retry 2
tunnel-group DefaultRAGroup ipsec-attributes
 tunnel-group 165..XX.XX.XX type ipsec-l2l
tunnel-group 165.XX.XX.XX ipsec-attributes
pre-shared-key *****
13 Replies 13
on the ASA, configure 'crypto ikev1 policy 300'. Do you have ikev1 enabled on the outside interface (crypto ikev1 enable outside) ?
If I am understanding the original post correctly the configuration has been done on the ASA but has not yet been done on the peer. If that is the case then there would not be any output for show crypto isakmp sa. There will be output only when there has been negotiation.
Rick
Rick
Dear Richard,
Got your point still configuration is not done on other end asa fw but also on running config i am unable to find below config that i have done on cli.
When i done sh run i am unable to find below commands that i have already configure & did not get any error.
encryption 3des
hash md5
group 2
lifetime 86400
what if you enter:
crypto ikev1 policy 1
encryption 3des
hash md5
group 2
lifetime 86400
Dear Ricahrd,
Configuration is done on other end also but still i am not getting output from sh crypto isakmp sa & also on other end firewall we are not getting any output from sh crypto isakmp sa.?
Can you please suggest any command to check the logs on this .??
In re-reading this discussion I notice this in the original post
these are the same objects used in the crypto acl and it looks like you are translating the traffic that you are sending through the vpn. That is pretty unusual and I wonder if you really meant to do this.
It might help us to understand the issue if you would post the config from your ASA. For troubleshooting what is going on I would suggest these steps:
- be sure that logging is enabled and working, especially logging monitor
- debug crypto isakmp 100
- attempt to bring up the vpn
- post any output that you receive
Rick
Rick
Dear  Richard ,
I have call the CRYPTO_NAT because of below nat & can you please let me know how to enable log, disbale the log so firewall will not goes in hang state.
nat (inside) 0 access-list CRYPTO_NAT
Dear Richard,
Also i am still unable to see below
encryption 3des
hash md5
group 2
lifetime 86400
& also please let me know is this some bug on my ASA please find the sh ver output below.
PMMZA-ASA5505#
PMMZA-ASA5505# SH VER
PMMZA-ASA5505# SH VERsion
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(5)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
PMMZA-ASA5505 up 119 days 22 hours
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
 0: Int: Internal-Data0/0    : address is f4cf.e213.a50f, irq 11
 1: Ext: Ethernet0/0         : address is f4cf.e213.a507, irq 255
 2: Ext: Ethernet0/1         : address is f4cf.e213.a508, irq 255
 3: Ext: Ethernet0/2         : address is f4cf.e213.a509, irq 255
 4: Ext: Ethernet0/3         : address is f4cf.e213.a50a, irq 255
 5: Ext: Ethernet0/4         : address is f4cf.e213.a50b, irq 255
 6: Ext: Ethernet0/5         : address is f4cf.e213.a50c, irq 255
 7: Ext: Ethernet0/6         : address is f4cf.e213.a50d, irq 255
 8: Ext: Ethernet0/7         : address is f4cf.e213.a50e, irq 255
 9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 3, DMZ Restricted
Inside Hosts                   : Unlimited
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 10
Dual ISPs                      : Disabled
VLAN Trunk Ports               : 0
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has a Base license.
Serial Number: JMX1851Z0NF
Running Activation Key: 0xf43afe60 0xa8931b81 0xec811134 0xa2b4a4d0 0xcf263eb8
Configuration register is 0x1
Configuration last modified by enable_15 at 20:03:32.968 UTC Wed Nov 14 2018
PMMZA-ASA5505#
PMMZA-ASA5505#
PMMZA-ASA5505#
PMMZA-ASA5505#
PMMZA-ASA5505#
PMMZA-ASA5505# SH INVE
PMMZA-ASA5505# SH INVEntory
Name: "Chassis", DESCR: "ASA 5505 Adaptive Security Appliance"
PID: ASA5505           , VID: V13     ,
Also please let me know there is earlier one crypto isakmp policy 100 is configure so my question is this multiple tunnel can use single phase 1 like crypto isakmp policy 100
 encryption 3des
 hash md5
 group 2
 lifetime 86400
Realizing that you are running 8.2(5) which uses the nat0 approach to address translation does explain the ACL that I questioned. I was thinking in terms of more recent versions which use a different approach to configuring nat. So that entry would be correct.
I am not sure why you are not seeing the isakmp policy 300. Yes it is possible for multiple vpn tunnels to use a single isakmp policy 100.
Rick
Rick
Dear Richard,
Can you please let me know how can we take complete backup of firewall other then sh run that include all licenses/certificate.
We can use tftp for this but can just help me with commands also i am at remote side so please suggest accordingly.
If you want to backup including certificates etc use the backup facility in ASDM. It gives you much more than the copy run command does.
Rick
Rick
Dear Richard,
ASDM is not work properly so i need to use CLI for this.
Please suggest on this
If ASDM is not working properly then you can do much of the backup processing from CLI. For many functions on ASA you can do the same function using ASDM or using CLI. But this is one area where ASDM and CLI do not match up. In ASDM there is one function which backs up multiple things. Using CLI it will take multiple commands, each command backing up one thing.
Rick
Rick
