IPv4 Routing Checkbox in CISCO SG350 GUI
Mo_Sa
I am connecting MKC Modules to the switch, but they lose their IPs once they are connected to the switch.
After many tests I unchecked this option (IPv4 Routing: image attached) and the IPs are no more lost and it worked.
I couldnt find any logical explanation..
Can you please support...
I used to use the SG300 but it didnt has this check box.
Deepak Kumar
I never worked on MKC modules (or I didn't remember the name) so please share your Switch configuration with details that where are you trying to fix IP which is changing on the switch.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
