is it possible to add up some commands to the initial running-config?
Hi all,
Is it possible to tune up the initial running-config in order to add some commands up (like boot system tftp://... or reload in 24:00)  so those commands get embedded into the default running-config, I mean, the one you get after typing  "erase startup-config" and then "reload" ?
This way you would automatically get those commands everytime you clear the statup-config, saving you the initial configuration task?
Kind Regards,
Abzal
Level 7
Level 7
You can just save running-config and copy it to external TFTP server as backup config. Then can anytime copy it again to the router.
Hope it will help.
Best regards,
Abzal
Abzal
Level 7
Level 7
Hope it will help.
Best regards,
Abzal
Hi Abzal,
Thanks for your early reply. Your solution is good and is practical, but I would like to know if there is a way to modify the default running-config appearing after performing an "erase startup config" and "reload".
This "blank" running-config depends on the number of interfaces of the router, so it is not always the same.
So I guess there might be a way to slightly modify it to add up some commands.
Kind Regards,
I did some search and there is a solution for you. I never tried but it can work.
Have a look on this thread perhaps it will work for you:
https://supportforums.cisco.com/thread/2154969
If it work for you let me know.
Hope it will help.
Best regards,
Abzal
