Is it possible to change the UDP port for syslog messages on a Cisco 9500 switch?
shanecanavan
Is there any way to change the port that is used for syslog messages on a Cisco 9500 switch?
By default this is set to UDP port 514.
There doesn't seem to be a command to change the port.
Thanks very much,
Shane
nielsb
Having the same issue, this has been a feature on any Cisco router or switch previous to the Nexus line!!
