Is possible load configuration of Cisco Router 1801 on Cisco Router 1841 with HWIC 1ADSL?
mianid
Hi, I have just received the Cisco 1841 v 05 router and I wanted to know if it was possible to load on this router to my current router's setup, the cisco 1801 v 05.
Obviously, on the Cisco 1841 is installed HWIC 1ADSL to use the connection.
Is it possible or I can set up the 1841 step by step?
Thank you.
Mark Malone
Hi yes you could  but your interfaces may be different on each router , so it may not take the config exactly I would check that make sure they match first , if they do your good to go if not I would do it step by step for interfaces but you should be able to copy an paste the global config no problem which will be the majority of stuff like acls etc
Currently on the router I using only the VPN and I opened some ports, in addition to the normal 7 mb adsl connection.
Do you think that these configurations can be charged without any problems?
yes that's standard changes there should be no problem doing that , if you have an issue with it just post what you see and we can help
