Is there a reserved range for VXLAN VNI?
jpl861
Level 4
Level 4
Is there a reserved range for VXLAN VNI that I am not supposed to use? I did a very simple spine and leaf topology,  initially I have two spines and two leaves but due to some issues, I turned off the second spine.
I tried to map the following
Vlan 100 to VNI 1100
Vlan 101 to VNI 1101
I really couldn't make it work regardless if I do multicast or manual peering with ingress-replication.
And then I decided to do wireshark capture to see how the packets flow. From the source host, the encapsulation is correct,  it is using vlan 100 as the dot1q vlan. And then I saw it being transported across the network down to the destination. However, I saw that vlan ID changed when the second leaf sends the frame to the destination. It is tagging the frame with VLAN 1100 instead of VLAN 100. I really couldn't see any faults with the configuration as I only copied the vlan and nv overlay configurations to both leaves.
And then I tried to change the mapping.
Vlan 100 to VNI 100100
Vlan 101 to VNI 100101
Then it worked like magic.
Hello
I have not implemented vxlan on cisco but in aruba for evpn vlxan the VNI range is not restricted to but is recommended  to use 10000 + vlan x
Kind Regards
Paul
 VNI values are from 4096 to 16,777,215
So, this would be out of the range
https://www.ciscopress.com/articles/article.asp?p=2999385&seqNum=3
Got it! It's just weird because the CLI says I can start with 1.
nx9kv3(config-vlan)# vn-segment ?
<0-0> Segment-id
<1-16777214> Segment-id
