advice product info
nlprestcom
Hello,  I need a switch  layer 3 rack 1U  19" with these specs :
WAN: 1 port 10/100/1000 Base-T/RJ45 1 port combo 10/100/1000 Base-T/SFP
LAN: 8 port switching 10/100/1000 Base-T/RJ45
1 port RJ45
1 port USB 2.0
DRAM: 512MB
FLASH: 256MB
SSL VPN
DES, 3DES, AES128, AES192,AES 256
DynamicMultipointVPN ( DMVPN)
Tunel IPSEC: 50
Port security static dinamic
lntrusionorevention
PolicyBasedRouting
CoS DSCP
ResourceReservation Protocol
Real-Time Transport Protocol
Generic routingencapsulation (GRE)
Multipoint Generic routingencapsulation (MGRE)
Layer 2 Tunneling Protocol(L2TP)
Layer 3 Tunneling Protocol version 3 (L2TPv3)
NetworkAddressTranslation (NAT)
DynamicHostConfiguratlonProtocol(DHCP)
DynamicDomainNameSystem (DNS)
Access Control lists (ACLs)
IPV4 IPV6 multicast
Open ShortestPathFirst (OSPF)
Border Gateway Protocol (BGP)
Enhaced Interior Gateway Routing Protocol (EIGRP) Virtual RouteForwarding(VRF)
HSRP MHSRP
Auto MDI/MDX
VLAN
MAC filtering
Switched Port Analyzer (SPAN)
Storm Control
authentication port 802.l x
RADIUS TACACS+
Telnet
SNMPv3
SSH
Command line interface (CLI)
Web management
Jo49201
Switch cannot do site to site vpn or client vpn or Nat.
You should look at Flavio Link for ISR.
SSL VPN:  DES, 3DES, AES128, AES192,AES 256
Tunel IPSEC: 50
