Is there any way that you could help me with a 3560 switch config?
Basically a 48-port 3560-X switch will be used with NM-1G module (to be used for uplinks to the 6506-E distribution switches which are configured in VSS mode). You can use the following VLAN numbers:
IDF Data VLAN = 101
Voice VLAN = 151
Wi-Fi VLANs = 32, 34, 36 (one VLAN per SSID) => trunk port to the APs
6 Replies 6
InayathUlla Sharieff
Hi Sherwin,
Here is the below config which I can think of based on layer 2.
1- Vlans creation.
Conf t
Vlan 101,151,32,34,36
1.a) Allowing all the vlans on the trunk ports connecting to 6500.
Int g1/1/1
Switchport trunk encapsulation dot1q
Switchport mode trunk
Switchport allowed vlan 1,101,151,32,34,36
Exit
Int G1/1/3
Exit
2- Now you need to define the ports for respective devices. (I.e which ports needs to be on Data, Voice and Wifi)
Eg: If you are connecting just PC to the Switch then this should below to the Data vlan. ( Suppose F0/1 – connected to vlan 101)
Int f0/1
Switchport
Switchport mode access
Switchport access vlan 101
B) For Voice VLAN
Int f0/2
Switchport
Switchport access vlan 151
If in case you want to have Data and Voice VLAN on the same port then configure this:
(Pc---Phone----Switch)
Int f0/3
Switchport access vlan 101---Data vlan
Switchport voice vlan 151
Exit
Voice vlan explained here;
https://learningnetwork.cisco.com/message/194922#194922
C- Wifi VLAN:
interface X
switchport access vlan 101
switchport trunk native vlan 101
switchport trunk allowed vlan 32,34,36
switchport mode trunk
Inayath
*Plz rate all usefull posts
thank you Inayath, appreciated it! really!
You got a "4" Inayath?????
Someone doesn't like your answer.
Leo,
I belive it was not satisfying answer....not upto his expectation hence probably rated 4...:-)
Rated, Inayath.
Thanks Leo.
