is ws-x4506-gb-t supported with SUP5, ws-x4516 in an 4503E chassis
Thomas Struth
after reading several documents, it is not 100% clear for me,
if the ws-x4506-gb-T linecard is supported with a SUP5 ( ws-x4516 ) with ios 15.x
in a 4503E Chassis . It is listed as a "classic" line card, but some docs
say a sup5-10ge or sup6e is needed .
thanks in advance, Thomas
5 Replies 5
Hello Thomas,
As per the below doc it is supported.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/product_data_sheet09186a00801fcaba.html
Look under table 8.
Hope this helps,
Madhu
***Please rate useful posts****
I Just had a check of some cases and i can see these 2 work together though could not find with 15.2
However i feel it should work.
Madhu.
*** Please rate useful posts***
Hello Madhu,
many thanks for your replies, this is a very good info!  The sup5 we use
is running ios 15.0.2.sg8, not 15.2.  , and now I am confident it will work.
best regards, Thomas
Hello Thomas,
Thanks keep me posted on the result.
Also if you could rate my posts it would be great .
Madhu.
Hello Thomas,
I think i made a typo..i dint specifically mean 15.2 rather i said 15.X. However i think it still work. If i get a chance i will try to check in a lab soon to confirm on the ios you mentioned if these models are available.
Madhu
