Hi.
Does anyone know of any compatability issues when configuring an iSCSI node on a HP P4500 connecting to a FEX as a vPC on a pair of 5K's?
The LAG ID's are different on the incoming links from the SAN node:
cam-dat-asw-sfy-01# sh vpc consistency-parameters vp 8
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
Shut Lan 1 No No
STP Port Type 1 Default Default
STP Port Guard 1 None None
STP MST Simulate PVST 1 Default Default
lag-id 1 [(7f9b, [(7f9b,
0-23-4-ee-be-1, 8008, 0-23-4-ee-be-1, 8008,
0, 0), (ffff, 0, 0), (ffff,
9c-8e-99-19-3e-7a, 11, 9c-8e-99-19-3e-7a, 9,
0, 0)] 0, 0)]
mode 1 active active
Speed 1 1000 Mb/s 1000 Mb/s
Duplex 1 full full
Port Mode 1 access access
MTU 1 1500 1500
Admin port mode 1
Allowed VLANs - 208 208
Local suspended VLANs - - -
8 Po8 up failed vpc port channel 208
mis-config due to vpc
links in the 2 switches
connected to different
I've got vPC working on two physical servers connected to these 5K's and had Cisco confirm the config as ok.
Can anyone help? Has anyone set up vPC connected to a SAN node?
Paul
