ISP failover using IP SLA???
HI,
I am trying to configure ISP failover using IP SLA tracking in Cisco 3900 router(C3900-SPE100/K9).
I want to configure below commands:
R1(config)# ip sla 1
R1(config)# icmp-echo 2.2.2.2 source-interface FastEthernet0/0
R1(config)# timeout 1000
R1(config)# threshold 2
R1(config)# frequency 3
R1(config)# ip sla schedule 1 life forever start-time now
But the problem is i seen only below commands in the router:
Router(config)#ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
  server     IPPM server configuration
Please help me to configure IP sla static route tracking in Cisco 3900 series router.
Janardhna
The_guroo_2
Level 2
Level 2
Its not recommended to use IP SLA for thi pupose (though in IT you can do anything) can you xplainyour network in brief and i will give you better option...Are yo using any routing protocol with you ISP...tell me more abt it
It is simple. I have one router and my two ISP connections are terminated in my Cisco 3900 router. I have two static default routes points to the gateways of respective ISPs.
Just here i like to configure ISP failover using ISP SLA tracking. I am not seen any commands on this Router.
Please help me to solve this issue.
Janardhan
What IOS version do you have? Also, could you be running AAA on this router and not have sufficent access for these commands? This can also happen if someone has set you up with a privilege level.
