ISR 4321 - lan to lan routing \ switching \ Layer 3
James Reeve
I need to join 2 lan's at full gigabit speed.
So I got an ISR 4321 and configured ip's on 0/0/0 and 0/0/1 and the hosts connect to the ISR at gigabit speed but the file copy across the router is 5-10MBps.
So host A (10.1.0.253) > 0/0/0 on ISR 10.1.0.254 > < 0/0/1 on ISR - 10.2.1.254 > Host B 10.2.1.253.
Hosts A and B represent single layer 2 switched subnets.
Guessing I should be seeing 100MBps across the link after the bits to bytes conversion.
Am I missing something here ?
thanks
James
5 Replies 5
Joseph W. Doherty
No interface errors (on host ports)?
You should also look for the possibility of duplex mismatch on the interfaces. This is something that would impact throughput.
Rick
Rick
Both ports are connecting at a gig - it's the throughput that's low.
I'm not convinced that routing the two networks is the best way to do it.
thanks
James
The ISR 4321 has a default throughput cap of 50Mbits (upgradeable to 100 with a key)
No errors. I think it's that it's routing between 0/0/0 and 0/0/1 when it should be routing vlans in a single interface.
The max bandwidth between the interfaces is 50Mbits with the default license.
Can't find any documented config for this router anywhere.
thanks
James
