ISR 4331 console port interface
wltoney@fbi.gov
Cannot not putty into ISR4331 router via console port
chrihussey
1- Are you able to communicate on a different switch / router with the same configuration?
2- Are you sure you are plugging into the console port and not the aux or management ethernet port?
3- Can you telnet/SSH to the router and check the console config?
Yes, make sure you are plugged into the light blue bottom left port. The 4331 also has the mini-USB option.
I cannot get the proper  usb mini console port driver for CISCO 4331 router
not get the proper driver software to access the console port
Leo Laohoo
What exactly are you seeing with the terminal?
