ISR4451-X/K9 High Memory Using
JiangBo Tao
SGCHGWANRT01#sho ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
SGCHGWANRT01 uptime is 1 day, 14 hours, 48 minutes
Uptime for this control processor is 1 day, 14 hours, 49 minutes
System returned to ROM by reload at 14:04:01 UTC Wed Mar 1 2017
System restarted at 18:51:33 UTC Sat Mar 11 2017
System image file is "bootflash:isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 EvalRightToUse appxk9
uck9 uck9 Permanent uck9
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4451-X/K9 (2RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FGL2106110W
4 Gigabit Ethernet interfaces
31 Serial interfaces
2 Channelized E1/PRI ports
8 Voice FXS interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7341807K bytes of flash memory at bootflash:.
SGCHGWANRT01#sho proce memory
Processor Pool Total: 1688360784 Used: 611363288 Free: 1076997496
lsmpi_io Pool Total: 6295128 Used: 6294296 Free: 832
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 745791360 281598440 429393752 2681 1071601 *Init*
0 0 1352 21392800 1352 0 0 *Sched*
0 0 339986776 333698704 6202584 104 103 *Dead*
0 0 0 0 2364368 0 0 *MallocLite*
1 0 5109536 255440 5016920 0 0 Chunk Manager
2 0 448 448 17864 0 0 Load Meter
3 0 22208 21416 30720 23 23 OVLD SPA Backgro
4 0 0 0 29864 0 0 Retransmission o
5 0 0 0 29864 0 0 IPC ISSU Dispatc
6 0 561176 26048 473096 0 0 RF Slave Main Th
7 0 65632 0 167496 0 0 EDDRI_MAIN
8 0 0 0 29864 0 0 RO Notify Timers
9 0 6240 448 35656 0 0 Check heaps
10 0 161348184 161389432 215112 53 2 Pool Manager
11 0 0 0 29864 0 0 DiscardQ Backgro
12 0 448 448 29864 0 0 Timers
13 0 0 0 17864 0 0 WATCH_AFS
14 0 0 0 29864 0 0 MEMLEAK PROCESS
15 0 1125776 1027032 128608 2913 2913 ARP Input
16 0 23528 23528 29864 23 23 ARP Background
17 0 448 448 29864 0 0 ATM Idle Timer
18 0 0 0 29864 0 0 ATM ASYNC PROC
19 0 0 0 29864 0 0 CEF MIB API
20 0 0 0 29864 0 0 AAA_SERVER_DEADT
21 0 0 0 53976 0 0 Policy Manager
22 0 448 448 29864 0 0 DDR Timers
23 0 141840 25088 144592 240 240 Entity MIB API
24 0 18880 18880 29864 0 0 PrstVbl
25 0 448 448 29864 0 0 Serial Backgroun
26 0 0 0 17864 0 0 RMI RM Notify Wa
27 0 448 448 41864 0 0 ATM AutoVC Perio
28 0 448 448 29864 0 0 ATM VC Auto Crea
29 0 0 0 29864 0 0 IOSXE heartbeat
30 0 0 0 29864 0 0 IPC Apps Task
31 0 0 0 29864 0 0 ifIndex Receive
32 0 0 0 29864 0 0 IPC Event Notifi
33 0 0 0 29864 0 0 IPC Mcast Pendin
34 0 0 0 29864 0 0 ASR1000 appsess
35 0 0 0 29864 0 0 IPC Dynamic Cach
36 0 0 0 29864 0 0 IPC Service NonC
37 0 0 0 29864 0 0 IPC Zone Manager
38 0 0 0 29864 0 0 IPC Periodic Tim
39 0 0 0 29864 0 0 IPC Deferred Por
40 0 0 0 29864 0 0 IPC Process leve
41 0 2192 0 32056 0 0 IPC Seat Manager
42 0 0 0 29976 0 0 IPC Check Queue
43 0 0 0 29864 0 0 IPC Seat RX Cont
44 0 0 0 29864 0 0 IPC Seat TX Cont
45 0 0 0 29864 0 0 IPC Keep Alive M
46 0 0 0 29864 0 0 IPC Loadometer
47 0 0 0 29864 0 0 IPC Session Deta
48 0 6016 6016 29864 6 6 SENSOR-MGR event
49 0 0 0 29864 0 0 Compute SRP rate
50 0 0 0 53864 0 0 License IPC stat
51 0 0 0 53864 0 0 License IPC serv
52 0 0 0 29864 0 0 Net Input
53 0 448 448 29864 0 0 GraphIt
54 0 448 448 53864 0 0 Dialer event
55 0 0 0 29864 0 0 SERIAL A'detect
56 0 132296 262488 31040 296 296 crypto sw pk pro
57 0 0 0 29864 0 0 IOSXE signals IO
58 0 0 0 29864 0 0 client_entity_se
59 0 3264 0 33128 0 0 RF SCTPthread
60 0 3120 0 32984 0 0 CHKPT RG SCTPthr
61 0 448 448 53992 0 0 XML Proxy Client
62 0 288 1280 29864 0 0 License Client N
63 0 0 0 29864 0 0 Image License br
64 0 28704035064 28704037368 29864 0 0 Licensing Auto U
65 0 0 0 29864 0 0 License HA Consi
66 0 0 0 29864 0 0 Token Daemon
67 0 0 0 29864 0 0 Critical Bkgnd
68 0 446568 20968 220928 355 355 Net Background
69 0 7216 6720 54360 0 0 IDB Work
70 0 448 448 53864 1310 1310 Logger
71 0 218496 1968 29864 14 14 TTY Background
72 0 448 16856 53864 0 0 SXP CORE
73 0 2488 0 56352 0 0 CTS CORE
74 0 0 0 29864 0 0 BACK CHECK
75 0 172072 334328 63728 0 0 IF-MGR control p
76 0 285448 0 72384 652 652 IF-MGR event pro
77 0 448 448 29864 0 0 CTS HA
78 0 0 0 29864 0 0 CTS HA IPC flow
79 0 76578440 63826112 7632200 427074 427074 IOSD ipc task
80 0 4640 4640 101864 0 0 IOSD chasfs task
81 0 0 0 41864 0 0 REDUNDANCY FSM
82 0 0 0 17864 0 0 Punt FP Stats Du
83 0 448 448 17864 69808 69808 PuntInject Keepa
84 0 0 0 29864 0 0 SBC IPC Hold Que
85 0 0 0 29864 0 0 Environmental Mo
86 0 0 0 29864 0 0 RP HA Periodic
87 0 0 0 29864 0 0 cpf_msg_holdq_pr
88 0 0 0 29864 0 0 cpf_msg_rcvq_pro
89 0 0 0 29864 0 0 cpf_process_tpQ
90 0 0 0 17864 0 0 CEF RRP RF waite
91 0 0 0 41864 0 0 CONSOLE helper p
92 0 0 0 17864 0 0 XDR RRP RF waite
93 0 0 0 29864 0 0 REDUNDANCY peer
94 0 0 0 29864 0 0 100ms check
95 0 0 0 29864 0 0 CWAN APS HA Proc
96 0 10096 0 111960 0 0 RF CWAN HA Proce
97 0 0 0 29864 0 0 CWAN IF EVENT HA
98 0 0 0 29864 0 0 ANCP HA
99 0 0 0 29864 0 0 ANCP HA IPC flow
100 0 0 0 29864 0 0 QoS HA ID RETAIN
101 0 0 0 29864 0 0 CHKPT Test clien
102 0 0 0 29864 0 0 CHKPT Test clien
103 0 0 0 29864 0 0 CHKPT Test clien
104 0 0 0 29864 0 0 CHKPT Test clien
105 0 0 0 29864 0 0 CHKPT Test clien
106 0 0 0 29864 0 0 CHKPT Test clien
107 0 0 0 29864 0 0 CHKPT Test clien
108 0 0 0 29864 0 0 CHKPT Test clien
109 0 0 0 29864 0 0 CHKPT Test clien
110 0 0 0 29864 0 0 CHKPT Test clien
111 0 0 0 29864 0 0 CHKPT Test clien
112 0 0 0 29864 0 0 DHCPC HA
113 0 0 0 29864 0 0 DHCPD HA
114 0 0 0 29864 0 0 DHCPv6 Relay HA
115 0 0 0 29864 0 0 DHCPv6 Server HA
116 0 448 448 41992 0 0 SISF HA Process
117 0 0 0 29864 0 0 ARP HA
118 0 8506432 1484112 34728 871779 871773 IOSXE-RP Punt Se
119 0 0 0 29864 0 0 IOSXE-RP Punt IP
120 0 0 0 29864 0 0 IOSXE-RP SPA TSM
121 0 0 0 29864 0 0 Network-rf Notif
122 0 0 0 53864 0 0 Metadata HA
123 0 0 0 53864 0 0 FMD HA IPC flow
124 0 0 0 29864 0 0 IKE HA Mgr
125 0 0 0 29864 0 0 IPSEC HA Mgr
126 0 0 0 53864 0 0 Crypto PKI-HA
127 0 37464 61328 51400 0 0 RF Master Main T
128 0 3120 0 32984 0 0 RF Master Status
129 0 0 0 29928 0 0 IFCOM Msg Hdlr
130 0 448 448 29864 0 0 Compute load avg
131 0 1940512 3869760 35496 0 0 Per-minute Jobs
132 0 0 0 41864 0 0 Per-Second Jobs
133 0 448 448 101864 0 0 ISDN Timer
134 0 0 0 29864 0 0 Transport Port A
135 0 0 0 53864 1 1 ACT2 Crypto Engi
136 0 0 0 29864 0 0 AggMgr Process
137 0 16104 22071536 52808 0 0 EEM ED ND
138 0 0 0 29864 0 0 IOSXE-RP FastPat
139 0 448 448 29864 0 0 NGIO_BRI_POLL_DE
140 0 0 0 53864 0 0 ASYNC Input
141 0 0 0 29864 0 0 ASR1000-RP SPA A
142 0 0 0 29864 0 0 DSX3MIB ll handl
143 0 0 0 29864 0 0 fanrp_l2fib
144 0 0 0 29864 0 0 POS APS Event Pr
145 0 448 448 29864 0 0 netclk_process
146 0 0 0 29864 0 0 netclk_ha_proces
147 0 0 0 29864 0 0 FPD Management P
148 0 0 0 29864 0 0 FPD Action Proce
149 0 448 448 29984 0 0 FEC_Link_event_h
150 0 0 0 53864 0 0 MCP RP autovc pr
151 0 448 0 30312 0 0 Src Fltr backgro
152 0 0 0 53864 0 0 BFD HW EVENT
153 0 0 0 53864 0 0 BFD IPV6 ADDR CH
154 0 0 0 29864 0 0 ESG PM Main proc
155 0 448 448 29864 0 0 ESG MATM process
156 0 448 448 29864 4 4 FLEX DNLD MAIN
157 0 218400 448 247816 0 0 VNM DSPRM MAIN
158 0 0 0 29864 0 0 SSLVPN Register
159 0 0 0 53864 0 0 IPSec background
160 0 23493752 28709952 29992 27927 27927 DiagCard1/-1
161 0 8688 0 38448 2 2 SSH Event handle
162 0 0 0 29864 0 0 MGMTE stats Proc
163 0 0 0 41864 0 0 BGP Scheduler
164 0 0 0 29864 0 0 CWAN CHOCX PROCE
165 0 0 0 29864 0 0 CE3 Mailbox
166 0 0 0 29864 0 0 CT3 Mailbox
167 0 0 0 29864 0 0 HAL Mailbox
168 0 28320 28320 17864 419112 419112 MIP Mailbox
169 0 15469496 6413328 12348032 2304 10814 CWAN OIR Handler
170 0 0 0 29864 0 0 TP CUTOVER EVENT
171 0 0 0 29864 0 0 ASR1K ESMC Proce
172 0 42744 1040 70384 9 9 ACE event
173 0 4056 219328 32960 1206 1206 ACE HAPI
174 0 0 0 29864 0 0 ACE policy loade
175 0 0 0 29864 0 0 DC voltage MWI P
176 0 10096 0 39960 0 0 RTTYS Process
177 0 17080 448 46496 0 0 AAA Server
178 0 0 0 29864 0 0 AAA ACCT Proc
179 0 106664 7928 128736 0 0 ACCT Periodic Pr
180 0 34199224 11918440 379104 21517 21517 CDP Protocol
181 0 296 296 29864 0 0 DiagCard2/-1
182 0 73072 0 33040 0 0 Call Home Timer
183 0 408 0 54272 0 0 CEF switching ba
184 0 408 0 18272 0 0 ADJ NSF process
185 0 0 0 29864 0 0 EAP Framework
186 0 0 0 29864 0 0 EAP Test
187 0 448 448 29864 0 0 AAA Dictionary R
188 0 3472 0 33336 0 0 FHRP Main thread
189 0 3312 0 33176 12 12 TRACK Main threa
190 0 3312 608 33176 0 0 TRACK Client thr
191 0 3312 0 33176 0 0 VRRP Main thread
192 0 73016 528 102352 0 0 VRRS Main thread
193 0 0 0 41864 0 0 HQF TARGET DYNAM
194 0 0 0 53864 0 0 IEDGE ACCT TIMER
195 0 0 0 29864 0 0 ISG CMD HANDLER
196 0 448 448 29864 0 0 IP PORTBUNDLE
197 0 448 448 53864 0 0 IP Static Sessio
198 0 448 448 53864 0 0 DVLAN Config Pro
199 0 0 0 29864 0 0 IP Lite session
200 0 448 448 29864 0 0 IPAM/ODAP Events
201 0 98736 0 152600 0 0 IPAM Manager
202 0 448 448 53864 0 0 IPAM Events
203 0 16656 1952 68568 51 51 IP ARP Adjacency
204 0 66064 0 95928 0 0 IP ARP Retry Age
205 0 2432 0 56296 343 342 IP Input
206 0 0 0 29864 0 0 ICMP event handl
207 0 614384 339208 250576 0 0 mDNS
208 0 448 448 29864 0 0 PIM register asy
209 0 0 0 29864 0 0 IPv6 ping proces
210 0 448 448 53864 0 0 KRB5 AAA
211 0 196896 459424 173128 5131 5131 BGP I/O
212 0 448 448 29864 699 699 MOP Protocols
213 0 0 0 29864 0 0 AAA EPD HANDLER
214 0 0 0 29864 0 0 PM EPD API
215 0 0 0 53864 0 0 DM Proc
216 0 448 448 29864 0 0 PPP SIP
217 0 448 448 29864 0 0 PPP Bind
218 0 448 448 53864 0 0 PPP IP Route
219 866 1261272 1159560 153944 845 829 SSH Process
220 0 0 0 29864 0 0 RADIUS Proxy
221 0 0 0 29864 0 0 RIB LM VALIDATE
222 0 448 448 53864 0 0 SSM connection m
223 0 0 0 53864 0 0 SSS Manager
224 0 0 0 53864 0 0 SSS Policy Manag
225 0 0 0 29864 0 0 SSS Feature Mana
226 0 0 0 29864 0 0 SSS Feature Time
227 0 0 0 53864 0 0 SSS PM SHIM QOS
228 0 0 0 53864 0 0 LONG TO SHORT NA
229 0 0 0 29864 0 0 Timer handler fo
230 0 0 0 29864 0 0 Prepaid response
231 0 0 0 29864 0 0 Timed Policy act
232 0 0 0 29864 0 0 AAA response han
233 0 872 448 30288 69314 69314 Spanning Tree
234 0 0 0 29920 0 0 VRRS
235 0 38408 1392 66944 0 0 MKA
236 0 0 0 29864 0 0 Webauth client
237 0 1808 0 31672 0 0 Auth-proxy HTTP
238 0 0 0 29864 0 0 IP Admin SM Proc
239 0 0 0 29864 0 0 PPCP RP Stats Ba
240 0 448 448 53864 0 0 Ethernet LMI
241 0 448 448 41864 0 0 Ethernet OAM Pro
242 0 2592 448 104008 0 0 Ethernet CFM
243 0 3417280 3417280 29864 0 0 mcp callhome per
244 0 0 0 29864 0 0 IGMP Route Msg H
245 0 0 0 29864 0 0 IGMP Route Rx Pr
246 0 3120 0 32984 0 0 L2FIB Timer Disp
247 0 3448 200 32984 0 0 MLRIB L2 Msg Thr
248 0 0 0 29864 0 0 TEMPLATE HA
249 0 0 0 29864 0 0 DVLAN HA
250 0 0 0 29864 0 0 HDLC HA
251 0 448 448 29864 0 0 RG AR
252 0 448 448 53864 0 0 RG Faults Timer
253 0 448 448 53864 0 0 RG Protocol Time
254 0 448 448 53864 0 0 RG Transport Tim
255 0 0 0 29944 0 0 RG VP
256 0 0 0 29864 0 0 RABAPOL HA
257 0 0 0 29864 0 0 RABAPOL HA IPC f
258 0 448 448 29864 0 0 OCE punted Pkts
259 0 0 0 29864 0 0 O-UNI Client Msg
260 0 0 0 53864 0 0 LSP Tunnel FRR
261 0 0 0 53864 0 0 MPLS Auto-Tunnel
262 0 65632 0 167576 0 0 st_pw_oam
263 0 448 448 53864 0 0 ATM OAM Input
264 0 448 448 53864 0 0 ATM OAM TIMER
265 0 448 448 53864 0 0 SSS Mobility mes
266 0 8504 0 62368 0 0 IMA PROC
267 0 0 0 29864 0 0 Appnav auto disc
268 0 0 0 29864 0 0 Spanning Tree St
269 0 0 0 29864 0 0 CCM
270 0 0 0 29864 0 0 CCM IPC flow con
271 0 0 0 29864 0 0 SVM HA
272 0 0 0 29864 0 0 AC Switch
273 0 410512 200 22312 0 0 SBC initializer
274 0 0 0 29864 0 0 Inline Power
275 0 200 0 30064 0 0 Marvell wk-a Pow
276 0 448 448 29968 0 0 PI MATM Aging Pr
277 0 0 0 29864 0 0 VMATM Callback
278 0 1696 448 55112 0 0 DTP Protocol
279 0 448 448 29864 0 0 Dot1x Mgr Proces
280 0 448 448 41864 0 0 802.1x Accountin
281 0 0 0 29864 0 0 802.1x switch
282 0 408 0 30272 0 0 XDR background p
283 0 0 0 29864 0 0 XDR mcast
284 0 0 0 29864 0 0 XDR RP Ping Back
285 0 0 0 53864 0 0 XDR receive
286 0 0 0 29864 0 0 IPC LC Message H
287 0 0 0 29864 0 0 XDR RP Test Back
288 0 0 0 29864 0 0 FRR Background P
289 0 60328 24576 72784 12 12 CEF background p
290 0 408 0 54272 0 0 fib_fib_bfd_sb e
291 0 0 0 41864 0 0 IP IRDP
292 0 11744 0 41608 0 0 LSD HA Proc
293 0 408 0 30272 0 0 CEF RP Backgroun
294 0 0 0 29864 0 0 AAA System Acct
295 0 0 0 29864 0 0 SNMP Timers
296 0 448 448 29992 0 0 PPP Compress Inp
297 0 448 448 29864 0 0 PPP Compress Res
298 0 408 0 42272 0 0 Tunnel FIB
299 0 0 0 53864 0 0 Routing Topology
300 0 101848 27488 94784 10 10 CEF: IPv4 proces
301 0 408 1912 54272 4 4 ADJ background
302 0 408 0 54272 24 24 Collection proce
303 0 33584 312 87136 1 1 ADJ resolve proc
304 0 448 448 53864 0 0 Tunnel
305 0 0 0 29864 0 0 IP Traceroute
306 0 1010432 588344 618632 4520 4520 IP RIB Update
307 0 67688 66888 60592 27 27 IP Background
308 0 103088 4536 140416 2 2 IP Connected Rou
309 0 0 0 29864 0 0 Socket Timers
310 0 0 835712 53864 14892 14892 TCP Timer
311 0 1791896 7794560 56256 0 0 TCP Protocols
312 0 1808 0 247672 0 0 COPS
313 0 10544 448 63960 0 0 NGCP SCHEDULER P
314 0 448 1754016 53864 224 224 STILE PERIODIC T
315 0 448 448 53864 0 0 UV AUTO CUSTOM P
316 0 448 448 29864 0 0 Dialer Forwarder
317 0 984 200 30520 0 0 Service Routing
318 0 20896 5648 45112 0 0 SR CapMan Proces
319 0 1808 0 103672 0 0 HTTP CORE
320 0 67976 0 97840 0 0 DHCP SIP
321 0 448 448 53864 0 0 IP SIP Process
322 0 448 448 53864 0 0 IP Inband Sessio
323 0 4608 0 58472 0 0 Skinny Msg Serve
324 0 2747408 1676224 320744 1778 1778 ISDN
325 0 1312 880 54816 0 0 MFIB Master back
326 0 1952 448 43448 0 0 MVPN Mgr Process
327 0 872 448 42288 0 0 Multicast Offloa
328 0 0 0 29864 0 0 RARP Input
329 0 448 8408 41864 0 0 static
330 0 448 448 41864 0 0 App Route Proces
331 0 0 0 41864 0 0 IPv6 RIB Cleanup
332 0 0 0 41864 0 0 IPv6 RIB Event H
333 0 0 0 41864 0 0 IPv6 Static Hand
334 0 448 448 29864 0 0 DHCPv6 LQ client
335 0 0 0 29864 0 0 PAD InCall
336 0 448 448 53864 0 0 X.25 Background
337 0 0 0 29864 0 0 X.25 Encaps Mana
338 0 2609968 2609968 41864 0 0 QoS stats proces
339 0 38912 448 68328 0 0 SCTP Main Proces
340 0 0 0 53864 0 0 VPDN call manage
341 0 448 672 53864 0 0 Flow Exporter Ti
342 0 448 448 53864 0 0 Flow Exporter Pa
343 0 448 448 53864 0 0 Auth Manager
344 0 0 0 41864 0 0 EPM MAIN PROCESS
345 0 0 0 29864 0 0 Critical Auth
346 0 0 0 29864 0 0 SVM UT Process
347 0 0 0 29864 0 0 DCT Bkgd Process
348 0 0 0 29864 0 0 Timer Handler Pr
349 0 0 0 29864 0 0 VTEMPLATE IPC fl
350 0 408 0 30272 0 0 XDR FOF process
351 0 0 0 29864 0 0 RETRY_REPOPULATE
352 0 448 448 29864 0 0 EFP Errd
353 0 448 448 29864 0 0 Ether EFP Proces
354 0 448 448 29864 0 0 Ether Infra RP
355 0 0 0 29864 0 0 CFM HA IPC messa
356 0 0 0 41864 0 0 Ethernet PM Proc
357 0 448 448 41864 0 0 Ethernet PM Soft
358 0 0 0 53864 0 0 Ethernet PM Moni
359 0 0 0 41864 0 0 Ethernet Datapla
360 0 0 0 29864 0 0 ELB HA IPC flow
361 0 10944 440 40512 0 0 IGMPSN L2MCM
362 0 0 0 29864 0 0 IGMPSN MRD
363 0 0 0 29864 0 0 IGMPSN
364 0 0 0 29864 0 0 IGMPSN EI L2MCM
365 0 0 0 29864 0 0 IGMPSN EI Timer
366 0 0 0 29864 0 0 IGMPSN EI MRD Ti
367 0 0 0 29864 0 0 TCP HA PROC
368 0 0 0 29864 0 0 BGP HA SSO
369 0 153840 448 183256 0 0 RUDPV1 Main Proc
370 0 322912 448 352400 15 15 VoIP FPI Process
371 0 0 0 29864 0 0 IGMPQR
372 0 0 0 29864 0 0 IGMPQR-EI
373 0 140064 0 169928 0 0 L2FIB Event Disp
374 0 65528 0 119392 0 0 ATM HA
375 0 0 0 29864 0 0 ATM HA IPC flow
376 0 0 0 29864 0 0 FR HA
377 0 0 0 29864 0 0 GLBP HA
378 0 0 0 29864 0 0 HSRP HA
379 0 720 0 54584 0 0 MRIB RP Proxy
380 0 0 0 29864 0 0 IPv6 ACL RP Proc
381 0 0 0 29864 0 0 Netsync IPC flow
382 0 0 0 53864 0 0 RG If-Mgr Timer
383 0 448 448 53864 0 0 RG Media Timer
384 0 0 0 29864 0 0 VRRP HA
385 0 448 448 53864 1 1 MCPRP RG Timer
386 0 448 448 17864 0 0 L2X Switching Ev
387 0 424 0 54288 0 0 FRR Manager
388 0 0 0 29864 0 0 MFI Comm RP Proc
389 0 0 0 53864 0 0 Path set broker
390 0 0 0 53864 0 0 LFD Label Block
391 0 6880 0 36744 0 0 LDP HA
392 0 448 448 29968 0 0 MPLS VPN HA Clie
393 0 448 448 29864 0 0 TSPTUN HA
394 0 10096 0 63960 0 0 RSVP HA Services
395 0 448 448 29864 0 0 TE NSR OOS DB Pr
396 0 872 448 30288 0 0 MPLS TP HA
397 0 7080 3344 36944 0 0 VPWS Thread
398 0 0 0 29864 0 0 AToM HA Bulk Syn
399 0 0 0 29864 0 0 AToM MGR HA IPC
400 0 7432 640 36656 0 0 LFDp Input Proc
401 0 448 448 101984 19433 19433 CALL_STATS
402 0 448 448 29864 0 0 PPP NBF
403 0 896 448 18440 0 0 PfR BR Learn
404 0 448 448 29968 0 0 RBSCP Background
405 0 0 0 29864 0 0 XC RIB MGR
406 0 448 448 29864 0 0 ATIP_UDP_TSK
407 0 0 0 29864 0 0 Probe Input
408 0 0 0 29864 0 0 BD Route Msg Hol
409 0 0 0 29864 0 0 BD Route Rx Proc
410 0 10544 448 39960 0 0 BD MACSEC HA
411 0 448 448 29864 0 0 BD MACSEC HA CHK
412 0 0 0 29864 0 0 STP HA IPC flow
413 0 0 0 29864 0 0 AAA HA
414 0 98744 0 128608 0 0 AAA HA cleanup
415 0 0 0 29864 0 0 ac_atm_state_eve
416 0 0 0 29864 0 0 ac_atm_mraps_hsp
417 0 0 0 29864 0 0 AC HA Bulk Sync
418 0 0 0 29864 0 0 ATM HA AC
419 0 0 0 29864 0 0 BFD HA
420 0 4344 0 34208 0 0 CEM PROC
421 0 0 0 29864 0 0 CEM HA
422 0 0 0 29864 0 0 CEM HA AC
423 0 448 448 29864 0 0 PPPoE VRRS EVT M
424 0 448 448 29864 0 0 Inspect process
425 0 0 0 29864 0 0 IFCOM Msg Hdlr
426 0 2360 448 31776 0 0 URL filter proc
427 0 0 0 29864 0 0 VFI HA Bulk Sync
428 0 0 0 29864 0 0 VPDN CCM Backgro
429 0 0 0 29864 0 0 MAB Framework
430 0 0 0 29864 0 0 802.1x Critical
431 0 0 0 53864 0 0 SSL background p
432 0 0 0 29864 0 0 Select Timers
433 0 56392 448 85808 0 0 HTTP Process
434 0 448 448 29864 0 0 AAA Cached Serve
435 0 448 448 29864 0 0 ENABLE AAA
436 0 0 0 29864 0 0 EM Background Pr
437 0 0 0 29864 0 0 IDMGR CORE
438 0 2256 448 55672 0 0 LDAP process
439 0 0 0 53864 0 0 Opaque Database
440 0 0 0 29864 0 0 Key chain liveke
441 0 448 448 29864 0 0 LINE AAA
442 0 4488 4488 53864 0 0 LOCAL AAA
443 0 0 131264 41864 0 0 BGP Scanner
444 0 3092752 1879256 58704 1592 1592 TPLUS
445 0 6760 896 43728 0 0 EST Client
446 0 1147640 1146024 31480 116 116 NIST rng proc
447 0 4928 4928 41864 0 0 DynCmd Package P
448 0 448 448 29864 0 0 CRM_CALL_UPDATE_
449 0 0 0 53864 0 0 MPLS Auto Mesh P
450 0 103000 0 132864 0 0 MMA DB TIMER
451 0 448 448 29864 0 0 CCVPM_HDSPRM
452 0 560 560 29864 0 0 VSP_MGR
453 0 57864 448 159280 0 0 STUN_APP
454 0 1976 0 103840 0 0 STUN_TEST
455 0 99192 448 128608 0 0 Timer Library
456 0 0 0 29864 0 0 EAP Process
457 0 448 448 29864 0 0 Crypto Support
458 0 0 0 29864 0 0 IPSECv6 PS Proc
459 0 0 0 41864 0 0 QOS PERUSER
460 0 0 0 29864 0 0 crypto engine pr
461 0 0 0 53864 0 0 RSA background p
462 0 1473680 1321728 194208 9 9 Crypto CA
463 0 448 448 53864 0 0 Crypto PKI-CRL
464 0 0 0 53864 0 0 Crypto PKI-Rev-P
465 0 2032 0 55896 0 0 PKI OCSP
466 0 0 0 53864 0 0 PKI Revocation
467 0 0 0 53864 0 0 encrypt proc
468 0 0 0 29864 0 0 COND_DEBUG HA IP
469 0 872 448 30288 0 0 PIM HA
470 0 0 0 41864 0 0 SEGMENT ROUTING
471 0 872 448 54288 0 0 MMON PROCESS
472 0 448 448 17864 0 0 RSCMSM VOLUME MO
473 0 2600 0 32464 0 0 IP TRUST Registe
474 0 0 0 53864 0 0 CCSIP_EVENT_TRAC
475 0 499584 8064 545384 1848 1848 CCVPM_HTSP
476 0 448 448 29864 0 0 VPM_MWI_BACKGROU
477 0 456 0 30320 0 0 VPM_CABLE_STAT_P
478 0 1056 0 30920 0 0 VPM_CONN_CHK_BAC
479 0 864 0 30728 0 0 CCVPM_R2
480 0 13120 448 66536 0 0 Sip MPA
481 0 647480 0 689344 0 0 QOS_MODULE_MAIN
482 0 0 0 101864 0 0 VoIP AAA
483 0 456 0 102320 0 0 RPMS_PROC_MAIN
484 0 18664 0 264528 0 0 http client proc
485 0 49376 2592 151240 0 0 LICENSE AGENT
486 0 0 0 29864 0 0 EPHONE MWI Refre
487 0 0 0 29864 0 0 FB/KS Log HouseK
488 0 448 448 29864 0 0 EPHONE MWI BG Pr
489 0 10336 0 40200 0 0 Skinny HW confer
490 0 1416 448 102832 0 0 CTI Front End Pr
491 0 448 448 29864 0 0 CTI Call Control
492 0 448 448 29864 0 0 CTI Line Monitor
493 0 0 0 29864 0 0 CME CTI Device M
494 0 41816 448 71232 0 0 Dialog Manager
495 0 896 896 53864 0 0 VOICE REG BG Pro
496 0 448 448 53864 0 0 CME Extension Mo
497 0 0 0 29864 0 0 Presence Process
498 0 896 448 30312 0 0 Lawful Intercept
499 0 896 448 30312 0 0 LI messaging
500 0 0 0 29864 0 0 DS0 PCM Capture
501 0 57072768 133720 55524216 69 69 FLEX DSPRM MAIN
502 0 0 0 29864 0 0 FLEX DSP KEEPALI
503 0 302816 648 356032 87285 87285 Crypto IKEv2
504 0 0 0 29864 0 0 IKEv2 AAA handle
505 0 448 896 29864 0 0 CRYPTO MAP FREE
506 0 0 0 53864 0 0 Crypto INT
507 0 448 1336 53864 10 10 Crypto IKE Dispa
508 0 41176 448 94592 1 1 Crypto IKMP
509 0 0 0 41864 0 0 IPSEC manual key
510 0 10472 5528 56648 9 9 IPSEC key engine
511 0 0 0 101864 0 0 Crypto ACL
512 0 0 0 29864 0 0 Crypto PAS Proc
513 0 448 448 29864 0 0 GKM GM Process
514 0 432 0 30296 0 0 GKM KS PROCESS
515 0 0 0 41864 0 0 Licensing MIB pr
516 0 4464 0 34328 0 0 dcm_cli_engine
517 0 9624 464 39160 0 0 dcm_cli_provider
518 0 31488 7000 54664 0 0 DCM Core Thread
519 0 121888 473832 29864 0 0 AAA SEND STOP EV
520 0 0 0 53864 0 0 Test AAA Client
521 0 3887176 5160 3923880 852 820 EEM ED Syslog
522 0 375536 5160 412240 0 0 EEM ED Generic
523 0 13728 5160 50504 0 0 EEM ED Track
524 0 13696 5160 50400 0 0 EEM ED Routing
525 0 15224 5728 52000 0 0 EEM ED Resource
526 0 2347856 2347360 30360 570 570 Syslog Traps
527 0 714160 679896 251528 29 29 AFW_application_
528 0 448 448 29928 0 0 ICRM
529 0 0 0 29864 0 0 IFCOM Msg Hdlr
530 0 408 0 30272 0 0 Online Diag EEM
531 0 7170280 7129712 56536 9564 9564 SPA ENTITY Proce
532 0 448 448 53864 0 0 ISG MIB jobs Man
533 0 0 0 29864 0 0 SONET Traps
534 0 0 0 29864 0 0 Policy HA Timer
535 0 448 448 29864 0 0 ESG SPAN process
536 0 0 0 29992 0 0 PM Callback
537 0 96584 4104 146200 0 0 VLAN Manager
538 0 448 448 29864 0 0 VTPMIB EDIT BUFF
539 0 0 0 53864 0 0 IKEv2 FlexVPN Pr
540 0 1808 0 31672 0 0 IKEv2 Cluster Lo
541 0 448 448 29864 0 0 MCPRP UTD Timer
542 0 0 0 41864 0 0 BGP Consistency
543 0 17864 3640 43544 0 0 DCM snmp dp Thre
544 0 6256 464 35504 0 0 snmp dcm ma shim
545 0 16440 20136 41432 0 0 Bulkstat-Client
546 0 6856 464 35992 0 0 dcm_expression_p
547 0 1444160 27992 1446032 0 0 EEM Server
548 0 265448 198720 229048 0 0 Call Home proces
549 0 35584 936 33640 0 0 Call Home DS
550 0 3120 0 32984 0 0 Call Home DSfile
551 0 15368 1808 55424 0 0 EEM Policy Direc
552 0 0 7200 29864 148 148 ISDNMIB Backgrou
553 0 13504 5160 50208 0 0 EEM ED CLI
554 0 13504 5160 50208 0 0 EEM ED Counter
555 0 15488 5248 52104 0 0 EEM ED Interface
556 0 13504 5160 50208 0 0 EEM ED IOSWD
557 0 23600 5160 60304 0 0 EEM ED None
558 0 13592 5160 50296 0 0 EEM ED OIR
559 0 14680 5224 50896 0 0 EEM ED RF
560 0 13504 5160 50208 0 0 EEM ED SNMP
561 0 13504 5160 50320 0 0 EEM ED SNMP Obje
562 0 13696 5160 50400 0 0 EEM ED SNMP Noti
563 0 13808 5160 50512 0 0 EEM ED Timer
564 0 13504 5160 50208 0 0 EEM ED Test
565 0 13504 5160 50320 0 0 EEM ED Config
566 0 13504 5160 50208 0 0 EEM ED Env
567 0 19280 5160 55984 0 0 EEM ED DS
568 0 19280 5160 55984 0 0 EEM ED CRASH
569 0 13504 5160 50208 0 0 EM ED GOLD
570 0 426672 422984 57552 2597 2597 Syslog
571 0 0 111648 29864 0 0 CallMIB Backgrou
572 0 5152 0 59016 0 0 udp_transport Se
573 0 3928 568 33792 0 0 qos_mon_periodic
574 0 13592 5160 50296 0 0 EEM ED RPC
575 0 26928 1008 79784 0 0 RBM CORE
576 0 0 0 29864 0 0 ISSU Utility Pro
577 0 0 0 29864 0 0 IOSXE-RP Virtual
578 0 408 0 30376 0 0 Online Diag CNS
579 0 408 0 30272 0 0 Online Diag CNS
580 0 13504 5160 50208 0 0 EEM ED Ipsla
581 0 0 0 29864 0 0 IP SLAs Ethernet
582 0 0 0 29864 0 0 VDC process
583 0 0 0 29864 0 0 trunk conditioni
584 0 6240 0 36104 0 0 trunk conditioni
585 0 0 0 29864 0 0 IPC ISSU Version
586 0 0 0 29864 0 0 IPC ISSU Version
587 0 0 0 29864 0 0 IPC ISSU Version
588 0 0 0 29864 0 0 IPC ISSU Version
589 0 0 0 29864 0 0 IPC ISSU Version
590 0 0 0 29864 0 0 IPC ISSU Version
591 0 0 0 29864 0 0 IPC ISSU Version
592 0 0 0 29864 0 0 IPC ISSU Version
593 0 0 0 29864 0 0 IPC ISSU Version
594 0 0 0 29864 0 0 IPC ISSU Version
595 0 0 0 29864 0 0 IPC ISSU Version
596 0 0 0 29864 0 0 IPC ISSU Version
597 0 0 0 29864 0 0 IPC ISSU Version
598 0 0 0 29864 0 0 IPC ISSU Version
599 0 0 0 29864 0 0 IPC ISSU Version
600 0 0 0 29864 0 0 IPC ISSU Version
601 0 0 0 29864 0 0 IPC ISSU Version
602 0 0 0 29864 0 0 IPC ISSU Version
603 0 0 0 29864 0 0 IPC ISSU Version
604 0 0 0 29864 0 0 IPC ISSU Version
605 0 0 0 29864 0 0 IPC ISSU Version
606 0 0 0 29864 0 0 IPC ISSU Version
607 0 0 0 29864 0 0 IPC ISSU Version
608 0 0 0 29864 0 0 IPC ISSU Version
609 0 0 0 29864 0 0 IPC ISSU Version
610 0 0 0 29864 0 0 IPC ISSU Version
611 0 0 0 29864 0 0 IPC ISSU Version
612 0 10096 0 40016 0 0 IPC ISSU Version
613 0 0 0 29864 0 0 IPC ISSU Version
614 0 0 0 29864 0 0 IPC ISSU Version
615 0 0 0 29864 0 0 IPC ISSU Version
616 0 0 0 29864 0 0 IPC ISSU Version
617 0 0 0 29864 0 0 IPC ISSU Version
618 0 0 0 29864 0 0 IPC ISSU Version
619 0 0 0 29864 0 0 IPC ISSU Version
620 0 0 0 29864 0 0 IPC ISSU Version
621 0 0 0 29864 0 0 IPC ISSU Version
622 0 0 0 29864 0 0 IPC ISSU Version
623 0 0 0 29864 0 0 IPC ISSU Version
624 0 0 0 29864 0 0 IPC ISSU Version
625 0 0 0 29864 0 0 IPC ISSU Version
626 0 0 0 29864 0 0 IPC ISSU Version
627 0 0 0 29864 0 0 IPC ISSU Version
628 0 0 0 29864 0 0 IPC ISSU Version
629 0 0 0 29864 0 0 IPC ISSU Version
630 0 0 0 29864 0 0 IPC ISSU Version
631 0 0 0 29864 0 0 IPC ISSU Version
632 0 0 0 29864 0 0 IPC ISSU Version
633 0 0 0 29864 0 0 IPC ISSU Version
634 0 0 0 29960 0 0 IPC ISSU Version
635 0 0 0 29864 0 0 IPC ISSU Version
636 0 0 0 29960 0 0 IPC ISSU Version
637 0 0 0 29864 0 0 IPC ISSU Version
638 0 0 0 29864 0 0 IPC ISSU Version
639 0 0 0 29864 0 0 IPC ISSU Version
640 0 0 0 29864 0 0 IPC ISSU Version
641 0 0 0 29864 0 0 IPC ISSU Version
642 0 0 0 29864 0 0 IPC ISSU Version
643 0 0 0 29864 0 0 IPC ISSU Version
644 0 0 0 29864 0 0 IPC ISSU Version
645 0 0 0 29864 0 0 IPC ISSU Version
646 0 0 0 29864 0 0 IPC ISSU Version
647 0 0 0 29864 0 0 IPC ISSU Version
648 0 0 0 29864 0 0 CWAN OIR IPC Rea
649 0 107051392 107051176 54080 0 0 mdns Timer Proce
650 0 34437344 51720 34761624 0 0 SBC main process
651 0 167640 448 221056 0 0 MRIB Process
652 0 448 448 29864 0 0 TRP_PSEUDOTIMER
653 0 4072 448 57488 0 0 TRPAPP
654 0 18583144 45528 476656 0 0 CC-API_VCM
655 0 4475096 4094680 1386304 7281 7281 DSMP
656 0 124864 23664 345472 34 34 VOIP_RTCP
657 0 448 448 53864 0 0 confmsp
658 0 6216576 3976360 654352 494 494 VTSP
659 0 52928 0 154792 0 0 TSP
660 0 3015392 448 3068808 0 0 VOICE_HA_ACTIVE
661 0 448 448 53864 0 0 VOICE_HA_STANDBY
662 0 79120 448 132536 0 0 Voip HA Session
663 0 1005016 1152 122696 0 0 Session Applicat
664 0 0 0 29864 0 0 Resource Measure
665 0 0 0 29864 0 0 Media Record
666 0 448 448 29864 0 0 Voice Player
667 0 3968 448 57384 0 0 RECMSPAPP
668 0 19144 528 48480 0 0 EEM Helper Threa
669 0 0 0 29864 27629 27629 ISDN From Driver
670 0 0 0 29864 0 0 SBC Msg Ack Time
671 0 19803224 16755296 2043792 4099 4095 CCH323_CT
672 0 0 0 29864 0 0 CCH323_DNS
673 0 2824144 448 3069560 0 0 CCSIP_SPI_CONTRO
674 0 0 0 53864 0 0 CCSIP_DNS
675 0 1444776 448 1546192 0 0 CCSIP_UDP_SOCKET
676 0 3365720 448 3467136 0 0 CCSIP_TCP_SOCKET
677 0 3370648 448 3472184 0 0 CCSIP_TLS_SOCKET
678 0 876088 202840 707696 35 35 RTPSPI
679 0 19840 19840 29864 18 18 OVLD SPA Backgro
680 0 20176 448 61592 4656 4656 IGMP Input
681 0 50807832 50797304 52392 4732 4732 PIM Process
682 0 0 0 41864 0 0 Mwheel Process
683 0 0 0 29864 0 0 mcast_rw_process
684 0 15504 4168 65200 0 0 MRIB Trans
685 0 312360 1008 48168 0 0 MFIB_init
686 0 64640 15712 90792 24 24 MFIB_cable
687 0 448 448 41864 0 0 MFIB_mrib_write
688 0 45248 3728 169352 7 7 MFIB_mrib_read
689 0 512 512 41864 0 0 MFIB_rate
690 0 448 448 41864 0 0 MFIB_backwalk
691 0 448 448 41864 0 0 MFIB_ppr_release
692 0 9038880 9028784 51960 0 0 MFIB_hw_stats
693 0 5552 1208 106208 51579 51579 HSRP Common
694 0 57024 10928 147960 56732 56732 HSRP IPv4
695 0 594928 376 243000 0 0 BGP Task
696 0 0 0 41864 0 0 BGP BMP Server
697 0 0 0 41864 0 0 BGP Event
698 0 0 0 29864 0 0 TCP Listener
699 0 122584 0 164576 0 0 IP SLAs Control
700 0 124560 0 178424 0 0 IP SLAs Responde
701 0 198779224 198746576 55488 1201040 1201040 IP SNMP
702 0 191256792 0 101864 0 0 PDU DISPATCHER
703 0 2124561536 2315631768 102032 3904 3904 SNMP ENGINE
704 0 1936 448 55464 0 0 IP SNMPV6
705 0 0 0 53864 0 0 SNMP ConfCopyPro
706 0 4585136 4891776 53864 4314 4314 SNMP Traps
707 0 2727296 1701072 1025152 17440 17438 SCCP Application
708 0 54848 448 108264 2 2 MLD
709 0 448 448 29864 0 0 Skinny MOH Event
710 0 58048 1672 56376 1 1 Skinny Socket Se
711 0 1936 1936 41864 20 20 Network Synchron
712 0 1488592 1453472 58328 7673 7673 NTP
713 0 0 0 41864 57069 57069 ISDN L2 Process
714 0 0 0 29864 0 0 ISDN L3 Timer Pr
715 0 0 0 29864 27631 27631 ISDN L2D SRQ Pro
716 0 0 0 29864 0 0 IFCOM Msg Hdlr
717 0 0 0 29864 0 0 IFCOM Msg Hdlr
718 0 448 448 29864 0 0 Inter Chassis Pr
719 0 2026104 314208 1133456 56 56 BGP Router
720 0 0 0 29864 0 0 BGP VA
721 0 16928 296 46560 0 0 DiagCard3/-1
722 0 296 296 29968 0 0 DiagCard4/-1
723 0 296 296 29864 0 0 DiagCard5/-1
724 0 50710664 50710664 29864 5 5 OVLD SPA Backgro
725 0 50707304 50707304 29864 5 5 OVLD SPA Backgro
726 0 50717352 50717352 29864 6 6 OVLD SPA Backgro
728 0 50684216 50684216 29992 5 5 OVLD SPA Backgro
617357848 Total
617357848 Total
Anyone can help me? thanks.
Philip D'Ath
