ISR4451-X NAT not working
Not applicable
Hi Guys,
Does anyone have experience configuring Nat on the new ISR's? I have the following setup:
LAN --> subinterface on ISR4451X in VRF A --> physical interface on ISR4451X in VRF B --> WAN
The LAN sub interface is the 'ip nat inside' interface and the physical WAN facing interface is the 'ip nat outside' interface. No matter how I configure NAT I don't seem to be able to get it to work - I don't ever see any translations or even any hits or misses in the 'sh ip nat statistics' output.
Config is:
ip access-list extended INSIDE
 permit ip x.x.x.x x.x.x.x any
ip nat inside source list INSIDE interface gi0/0/2 vrf A overload
int gig0/0/0.100
 ip nat inside
int gi0/0/2
ip nat outside
Thank you!
Adam
ciscoservice3
 Interfaces in your router must located in the same zone. But if you need forward and nat traffic with different zones, you solve this with ZBF. In ZBF create zones and write relationship with zones in different VRF( in both direction ).
