Issue after firmware upgrade
AlexKroon2654
Hi, I did a firmware upgrade for the C2960X from c2960x-universalk9-mz.150-2.EX5 to c2960x-universalk9-mz.152-7.E0a.bin
After Upgrading, the Switch Boot Up normally( All POST Passed), but the SYST Led get Amber and Below Message is shown every seconds: %ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization. This product may contain software that was copied in violation of Cisco's license terms. If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smartnet. Please contact Cisco's Technical Assistance Center for more information.
At this point, I can just ping or telnet the switch, but no packet forwarded from client to servers and vise versa. I format the flash and downgrade the iOS to old version, but the problem still exists. is there any way to overcome this problem?
When booting this happens.
*Mar 1 00:00:23.970: Read env variable - LICENSE_BOOT_LEVEL = Mar 30 01:27:38.076: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = No valid license found Dec 28 13:14:32.272: in Switch 0. Cannot read pid from Flexstack module Dec 28 13:15:30.877: %ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization. This product may contain software that was copied in violation of Cisco's license terms. If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smartnet. Please contact Cisco's Technical Assistance Center for more information. Dec 28 13:15:34.047: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack Dec 28 13:15:35.770: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down Dec 28 13:15:35.770: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down Dec 28 13:15:37.364: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan Dec 28 13:15:37.595: %DC-4-FILE_OPEN_WARNING: Not able to open flash:/dc_profile_dir/dc_default_profiles.txt Dec 28 13:15:37.595: %DC-6-DEFAULT_INIT_INFO: Default Profiles DB not loaded. Dec 28 13:15:40.950: %SYS-4-CONFIG_NEWER: Configuration from version 15.2 may not be correctly understood Dec 28 14:15:40: %SYS-6-Failed to generate persistent self-signed certificate. Secure server will use temporary self-signed certificate. CLOCKUPDATE: System clock has been updated from 13:15:40 UTC Wed Dec 28 2022 to 14:15:40 UTC Wed Dec 28 2022, configured from console by console. Dec 28 14:15:40: %SYS-6-CLOCKUPDATE: System clock has been updated from 14:15:40 UTC Wed Dec 28 2022 to 14:15:40 UTC Wed Dec 28 2022, configured from console by consol e. Dec 28 14:15:43: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down Dec 28 14:15:47: %SYS-5-CONFIG_I: Configured from memory by console Dec 28 14:15:47: %STACKMGR-5-SWITCH_READY: Switch 1 is READY Dec 28 14:15:47: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN Dec 28 14:15:47: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN Dec 28 14:15:48: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY Dec 28 14:15:49: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX5, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2014 by Cisco Systems, Inc. Compiled Fri 21-Feb-14 05:54 by prod_rel_team Dec 28 14:15:49: %SSH-5-ENABLED: SSH 1.99 has been enabled Dec 28 14:15:49: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.222.20 port 514 started - CLI initiated Dec 28 14:15:50: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45. Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/20: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/21: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/37: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/38: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/39: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/40: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/41: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/42: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/43: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/45: Power Device detected: IEEE PD Dec 28 14:15:51: %ILPOWER-7-DETECT: Interface Gi1/0/46: Power Device detected: IEEE PD Dec 28 14:15:52: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.222.19 port 514 started - CLI initiated Dec 28 14:15:52: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/21: Power granted Dec 28 14:15:52: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/20: Power granted Dec 28 14:15:52: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/38: Power granted Dec 28 14:15:52: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/41: PD removed Dec 28 14:15:52: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/45: PD removed Dec 28 14:15:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/37: Power granted Dec 28 14:15:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/40: Power granted Dec 28 14:15:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/39: Power granted Dec 28 14:15:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/42: Power granted Dec 28 14:15:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/43: Power granted Dec 28 14:15:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/46: Power granted Dec 28 14:15:53: %ILPOWER-7-DETECT: Interface Gi1/0/41: Power Device detected: IEEE PD Dec 28 14:15:53: %ILPOWER-7-DETECT: Interface Gi1/0/45: Power Device detected: IEEE PD Dec 28 14:15:54: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/41: Power granted Dec 28 14:15:54: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/48, changed state to up Dec 28 14:15:54: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/47, changed state to up Dec 28 14:15:54: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/45: Power granted Dec 28 14:15:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/48, changed state to up Dec 28 14:15:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/47, changed state to up Dec 28 14:15:57: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up Dec 28 14:15:57: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up Dec 28 14:15:57: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/46, changed state to up Dec 28 14:15:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up Dec 28 14:15:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/46, changed state to up Dec 28 14:15:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/43, changed state to up Dec 28 14:15:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/38, changed state to up Dec 28 14:15:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/37, changed state to up Dec 28 14:15:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/45, changed state to up Dec 28 14:15:59: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/40, changed state to up Dec 28 14:16:00: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/39, changed state to up Dec 28 14:16:00: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to up Dec 28 14:16:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/43, changed state to up Dec 28 14:16:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/45, changed state to up Dec 28 14:16:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/41, changed state to up Dec 28 14:16:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up Dec 28 14:16:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/37, changed state to up Dec 28 14:16:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/40, changed state to up Dec 28 14:16:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/39, changed state to up Dec 28 14:16:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to up Dec 28 14:16:02: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/23, changed state to up Dec 28 14:16:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/41, changed state to up Dec 28 14:16:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/23, changed state to up Dec 28 13:16:07: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.222.19 port 514 started - reconnection Dec 28 13:16:12: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.222.20 port 514 started - reconnection Dec 28 13:16:54: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/21, changed state to up Dec 28 13:16:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/21, changed state to up Dec 28 13:16:58: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20, changed state to up Dec 28 13:16:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20, changed state to up User Access Verification Username:
Mark Elsen
 - Review these : https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63972.html
                           https://www.cisco.com/c/en/us/support/docs/field-notices/641/fn64175.html
                           https://www.cisco.com/c/en/us/support/docs/field-notices/723/fn72399.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce1000,
I'm trying the 3th option, so first i upgraded to 152-7.E7. Then when i run the command: show platform sudi certificate sign nonce [nonce]
I'm not getting any info. What's next?
 - Contact Cisco TAC  ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
