issue: card and router does not communicate / card does not communicate with the devices plugged onto it
pal.pasztor
Dear all,
Can anyone help in this issue?
PID: ISR4331/K9        , VID: V02, SN: FLM2044W2X6 , module: SM-X-ES3-24-P
Thank you in advance.
6 Replies 6
apparently Ethernet-Internal1/0/0 maps to GigabitEthernet0/26 on the ESW. Either way, try the configuration below:
Router
no spanning-tree vlan 404
bridge-domain 1
bridge-domain 404
interface Ethernet-Internal1/0/0
no negotiation auto
service instance 1 ethernet
encapsulation dot1q 404
rewrite ingress tag pop 1 symmetric
interface BDI404
ip address 192.168.0.2 255.255.255.252
no cdp enable
Switch module:
ip routing
system mtu routing 1500
license boot level ipservices
spanning-tree mode pvst
interface GigabitEthernet0/2
switchport access vlan 404
switchport mode trunk
switchport protected
interface GigabitEthernet0/25
interface GigabitEthernet0/26
switchport trunk vlan allowed 404
vlan 404
interface Vlan1
interface Vlan404
ip address 192.168.0.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 192.168.0.2
Thank you Georg for your quick reply.
With this configuration I could test the communication between the module and the ISR4331 router; and it is working!
The main goal would be to let 2 routers talk via back-to-back connection (using the module SM-X as all the other ports of the routers are taken already)
I suspected that there was a problem between the card and the router first. But apparently this is not the case.
Basically the design what you have is:
ISR4331 SM-X-ES3-24-P port G2 --- <Nexus switches> --- ISR4331 SM-X-ES3-24-P port G2
One end should be 192.168.0.2 and the other .1 (/30)
Slight change in the very first configuration: on all the switches and switch modules :
switchport trunk allowed vlan 404
Have you ever met this kind of problem?
Could you please advise if the above setup could work with any alternative configuration template?
so basically you want GigabitEthernet0/2 on each router configured with an IP address ? I'll have a look, I'll get back with you...
The routed ports are taken so we would like to use the switch module.
The Nexus device is plugged onto G2 port of the SM-X-ES3-24-P module.
On the router as far as I know virtual interfaces must be used (BDI/SVI) for L3 communication.
This back-2-back connection will be used for iBGP; ISR1 must be able to ping ISR2.
The 2 ISRs are in different cities, and I have no visibility on the Nexus configuration/interconnection.
IOS verisons I tried:
isr4300-universalk9.03.16.01a.S.155-3.S1a-ext.SPA.bin
isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin
(to exclude possible IOS related bugs)
Let me know if I missed some important information or if I was not clear while describing the issue.
Thank you in advance for your time and support,
sorry for the delay.
How are both routers currently connected ? Can you post the configuration of the interface on the router that is connected to the router in the other city ?
Hi, I am sorry for the delay.
The good news are: The Back-2-Back connection is working now.
The bad news: unfortunately I am not sure what was the origin of the issue. It can be the interconnection between the 2 cities or the module just needed a reset. Probably both.
We did a switch module re-set, removed the related parts and re-configured the router and the built-in module exactly the same way as it was before.
Let me share with you the working configuration:
GigabitEthernet0/0/0   y.y.y.y         YES NVRAM  up                    up - LAN - towards customer
GigabitEthernet0/0/1   x.x.x.x         YES NVRAM  up                    up - WAN - towards PE
GigabitEthernet0/0/2   unassigned      YES NVRAM  down                  down - FW (reserved for future use)
Ethernet-Internal1/0/0 unassigned      YES unset  up                    up - B2B - to the router /other city
Ethernet-Internal1/0/1 unassigned      YES unset  up                    up
GigabitEthernet0       unassigned      YES NVRAM  down                  down
BDI404                 192.168.0.1     YES manual up                    up - the other end is 192.168.0.2
router:
no spanning-tree vlan 1,404
bridge-domain 1
bridge-domain 404
vlan internal allocation policy ascending
 no negotiation auto
  encapsulation dot1q 1
  bridge-domain 1 split-horizon group 0
 service instance 404 ethernet
  bridge-domain 404 split-horizon group 0
interface Ethernet-Internal1/0/1
 no negotiation auto
interface BDI404
 no cdp enable
Module:
 description Trunk to host router
interface Vlan1
 no ip address
switch connected to G2
vlan 404
name TEST
end
interface GigabitEthernet2/2
switchport
logging event link-status
load-interval 30
wrr-queue bandwidth 120 150 180
 wrr-queue cos-map 1 1 0 1 2
 wrr-queue cos-map 1 2 3
 wrr-queue cos-map 2 1 4
 wrr-queue cos-map 2 2 6 7
 mls qos trust dscp
end
Thank you again for having a look at it, really appreciate it!
