Issue:factory reset after reload show command ‘switch:' C9200L
WanisaCh
I factory reset after reload show switch:
i try upload image (cat9k_lite_iosxe.17.09.02.SPA.bin)
but command error and not found USB
i searched for a solution and followed it, but there not work.
Leo Laohoo
Copying of files, from USB, to the flash while in ROMMON is no longer allowed/supported.
While in ROMMON, the only ways are to boot the firmware from the USB or initiate the emergency-install from the USB.  They are the only options available.
Leo Laohoo
Thank you. I change USB to boot done.
