Issue setting just SSH V2 on Cisco 877
Nikolai.Derevko
Hi All,
I am setting a few of my routers to accept only SSH V2. I have gotten through 4/6 of them and i have hit a roadblock with 2 of them.
Once i am in the configuration terminal, it should be a straight forward command of "IP SSH VERSION 2"
When this is typed i get "Invalid input detected at Version 2"
This is running EXACTLY the same firmware as my existing routers,
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
It supports V2, so whats the issue??
The option isnt even there?
johnlloyd_13
Level 9
Level 9
Could you do:
enable
config t
ip ssh ver 2
Make sure you've got the right privilege level to configure this router.
